General
Installing LinuxCNC
Pentium D kernel
Pentium D kernel
Thank you received: 0
21 Aug 2010 04:06 #3834
by hengfo
I want to install EMC2 under Ubuntu 8.04.
My PC: Pentium D 3.0GHz+2G memory+Intel 945
Which kernel should I use, rtai or rtaismp?
I install the Live_CD first and then install rtaismp. I try both of kernels, rtai only shows one cpu core, rtaismp shows two but memory becomes to 887MB not 2G. What's the possible reason? Do I need to reset the kernel config files?
I also can not run EMC2 under rtaismp, the system message asksed me to choose rtai to run, not rtaismp. What should I do? And how can I decrease the value of latency test under rtaismp?
General
Installing LinuxCNC
Pentium D kernel
Time to create page: 0.098 seconds
