RPI4 Raspbian 64 bit & LinuxCNC
05 Sep 2023 11:53 - 05 Sep 2023 11:55 #279947 by Donno
RPI4 Raspbian 64 bit & LinuxCNCGive this a whirl
[url=https://drive.google.com/file/d/1Ve6LismgxL0OfYufkeU1Z0hzdWhbf_WJ/view?usp=drive_link]drive.google.com/file/d/1Ve6LismgxL0OfYu.../view?usp=drive_link[/url]
Wifi is turned off only cos I've found it can affect latency, boots straight into gui. You can turn it back on by editing /boot/broadcom/config.txt as root, then just rebooting.
user:cnc
passwd:linuxcnc
That image gives me bad latency
Last edit: 05 Sep 2023 11:55 by Donno.
05 Sep 2023 12:06 - 05 Sep 2023 12:31 #279949 by cornholio
How bad was it ? Compared to what ?
It's based on the same sources as was Rod uses, the only difference is I was experimenting with a 10Hz tick rate rather than a 250Hz.
I have found my self the image I use more regulary based on RPi OS or Raspbian or whatever they call it with a 5 series kernel is better.
OK for some reason the cmdline.txt is not being setup as it should. It is supposed to isolate cores 2 & 3. Config.txt is being setup as it should.
Last edit: 05 Sep 2023 12:31 by cornholio.
05 Sep 2023 12:20 #279953 by rodw
All feedback is useful as we sort this out.
Auto login is not enabled by default. I'm not sure if even th elinuxcnc installer does that.
I did think about it trying to enable it but I don't know how to edit settings in the middle of a file from a script.
We will leave i tto the user and we documented it here
linuxcnc.org/docs/2.9/html/getting-start...sec:_bookworm_tweaks
Using menu-config is the correct way to configure wireless. Its mentioned in my repository read.me
github.com/rodw-au/rpi-img-builder-lcnc
To set a static IP address, please follow the method in the hm2_eth docs
linuxcnc.org/docs/2.9/html/man/man9/hm2_...h%20static%20address
I have had a couple of technical issues here due to a corrupt file. I've recompiled and am rebuilding now
There is one thing I don't yet understand in the build procees which is how to skip the confusing menuconfig screen. If you have played with kernels before you will know what to do :) Working on it.
Comments saying you are getting bad latency is not helpful, please share a screen dump after a few minutes running
latency-histogram --nobase --sbins 1000
It would be good to see what people are getting.
For screenshots, I have been using flameshot (sudo apt install flameshot)
Cheers guys, its great to see a few giving it a go. It is very time consuming building and testing...
05 Sep 2023 12:29 #279954 by cornholio
Cornholio: That seems better in terms of general responsiveness.
dtoverlay=disable-wifi was already commented out in config.txt so WiFi was enabled but it ignored wpa_supplicant.conf and I had to setup the WiFi from menu-config.
It didn't auto-login as cnc but setting autologin-user=cnc in the "[Seat:*]" section of the /etc/lightdm/lightdm.conf does the trick.
There's still no raspi-config installed or available in the repos but maybe that's a generic bookworm change.
There's no dhcpcd installed so setting a static IP for the ethernet port (used for talking to my 7i76E in my use case) involves more Linux hackery than a Google search for setting a static IP on a Pi would suggest. A simple old school edit of /etc/network/interfaces sorts it.
When the screen is woken from screensaver, it asks for the cnc users password.
On the Good News front, running up linuxcnc worked and I could jog my steppers (I'm testing on my Lathe project which is currently just a pile of electronics and wires on the bench).
Is this feedback useful? I'm assuming the aim is to produce a RPi bookworm image that works for most folk.
Thanks for the feedback.
The screen saver thing is easily fixed in power settings (I can look into changing that without having to boot the image). For your Mesa card you have to give it a manual config, as the interface can't connect to a DHCP server(there should only be the motion card and computer directly connected). I thought network manager was installed for configuring the Network (It is set to install via the build config). I'll check that for sure. The setup should disable wifi & bluetooth during the build process.
I've never been a fan of auto login for Linux.
Raspberry config is a Rasp OS thing, this is based on Debian, apart from the kernel sources which are pulled from the RPi github page (the standard kernel has patches one of which is to work with the overlays), RT patches are from kernel.org. One thing that does annoy we, which I should fix, is that sudo doesn't require a user password. You might as well be running as root.
05 Sep 2023 12:34 #279955 by cornholio
Hey Rod are you installing task-xfce-desktop or just xfce ?
The former is what the debian setup program uses the (included lightdm greeter and other stuffs) latter is for installing if you want a second desktop..ie: you already have Mate or something like that.
05 Sep 2023 12:46 #279961 by rodw
Is that the governor? you can set that on the pi with menu-config. If not, where is it, we might be able to twaek the installer.
Also this next build I'm about to test is going to copy the deb files to the user's home directory. That will let you experiment with what we are building with the Debian default ARM RT kernel etc.
05 Sep 2023 13:00 #279963 by rodw
I've mentioned before, this can be fixed by deleting the file  in /etc/sudoers.d that contains the users name. We have tried to remove it in userscripst but it did not work but you can do it on the pi.
05 Sep 2023 13:07 #279966 by cornholio
I’d advise against the Debian kernel for anyone wanting spi and use mesaflash, it doesn’t have the required patches for the overlays. For Ethernet or direct gpio it should be ok.
I spent a lot of time finding this out, and looking for a fix. Apart from the Raspbian patched kernel there isn’t much that can be done.
05 Sep 2023 13:29 #279968 by ruffle
Cornholio: Ah yes sorry. Didn't grok that this is Debian with a different kernel. My aging brain automatically thought Raspbian.
Network Manager is indeed installed and works fine.
Power Settings do allow passwordless screensaver.
Personally I'm not that concerned about sudo passwords etc as for our use case it's a dedicated machine making chips but one can just change sudoers either way.
Next fun thing then is booting from SSD. I've dd'd the SDCard to my USB SSD (which was previously booting Raspian Bullseye so I know the RPi firmware is USB boot enabled) but when booting it gets stuck in a firmware not found loop.
The contents of the boot partition are quite different to a stock Raspbian so I guess I need to start Googling... unless someone's got a bright idea.
05 Sep 2023 14:20 #279976 by cornholio
Ok I fixed the screensaver thing.
Enabled the rainbow at turn on
Enabled sudo user password (stop you doing stupid things with root privileges)
Turned on wifi adapter
Diabled BT adapter
Turned on SPI
Set GPUMEM to 128M
Added isolcpus=2,3 and max.processor.cstate=1 to kernel cmdline(for latency issues)
Changed MC colour to default, similar to the old Norton DOS file manager (after 20 0dd years with Linux I still use it, great for transferring files from one computer to another as along as ssh server is running on the one you want to connect to).
Yeah the files are under /boot/broadcom (have to check where they usually are)
Added a launcher for Geany to bottom panel
Confirmed Network Manager can be used to connect and edit networks
It's now 00:20 in Australia, still need to dd the image from the sd card, compress the image and upload...I'll post in about 8-9 hours when done.
If anyone read this before then leave a comment and I'll see what I can do.
The following user(s) said Thank You: ruffle
