EMC non-realtime SUSE11.1 bombs out
09 Jun 2009 02:56 #400
by dwyersm
EMC non-realtime SUSE11.1 bombs out was created by dwyersm
I installed 2.3.1 using the instructions provided in INSTALL on my SUSE 11.1. When I run emc from root terminal wiindow, it closes when I choose any of the simulators except mini.
this is the error:-
EMC2 - 2.3.1
Machine configuration directory is '/usr/local/share/doc/emc2/examples/sample-configs/sim'
Machine configuration file is 'axis.ini'
Starting EMC2...
axis_manualtoolchange.hal:1: execv(hal_manualtoolchange) failed
axis_manualtoolchange.hal:1: hal_manualtoolchange exited without becoming ready
Shutting down and cleaning up EMC2...
Cleanup done
EMC terminated with an error. You can find more information in the log:
/root/emc_debug.txt
and
/root/emc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
I would like to run axis as simulator so that i can get to know it better on my home pc, and use the real time version at my cnc plasma outside in the shed.
any ideas.
regards,
Shane, Brisbane, Australia
this is the error:-
EMC2 - 2.3.1
Starting EMC2...
Cleanup done
/root/emc_debug.txt
and
/root/emc_print.txt
any ideas.
regards,
09 Jun 2009 12:02 #401
by BigJohnT
Replied by BigJohnT on topic Re:EMC non-realtime SUSE11.1 bombs out
Shane,
I don't have a clue about the SUSE stuff but you might just boot from the LiveCD and play with the sims that way.
I also have a CNC plasma cutter that I built and run with EMC2. For plasma cutting it is useful to program G64 Px.xxx to enable the naive cam detector for artsy fartsy stuff with lots of small arcs and lines. Take a look in the User Manual in the User Concepts chapter to better understand EMC's trajectory control.
09 Jun 2009 18:00 #408
by alex_joni
Replied by alex_joni on topic Re:EMC non-realtime SUSE11.1 bombs out
dwyersm wrote:
It would be interesting to see those..
Regards,
Alex
/root/emc_debug.txt
and
/root/emc_print.txt
Regards,
Alex
09 Jun 2009 21:27 #411
by dwyersm
Replied by dwyersm on topic Re:EMC non-realtime SUSE11.1 bombs out
sorry guys, I meant to display this file as well:-
emc_print.txt
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/local/bin
EMC2_TCL_DIR=/usr/local/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/local/lib/emc2/modules
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/local/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=emcsh
EMC2_IOSH=iosh
INIFILE=/usr/local/share/doc/emc2/examples/sample-configs/sim/axis.ini
PARAMETER_FILE=sim.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=emc.nml
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Killing task emcsvr, PID=11816
and here is "emc_debug.txt"
11816
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Is it possible to tell if I -
1. have installed correctly
2. am using correct run command, ie running "emc" in "/usr/share/emc2-2.3.1/scripts" from root console
I know a little about linux and cnc, but I suspect some idiosyncrasy with emc loader here maybe, then again SUSE 11.1 could be the culprit.
I could use the boot cd, but I sit in front of the PC and alternate between SUSE and XP a lot, having to load another OS could be a little awkward, after I have set everything up to be a comfortable dual purpose working environment.
I have all my drawings, cad, cam, internet, partitions, mount points etc set up in SUSE, and in a spare moment, I like just like to experiment with emc here at the home PC, and take any new knowledge, ideas, files, etc it down to the workshop realtime PC.
regards,
Shane, Brisbane, AU
emc_print.txt
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=emcsh
EMC2_IOSH=iosh
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=emc.nml
11816
regards,
Shane, Brisbane, AU
Time to create page: 0.123 seconds
