Run in place?
07 Sep 2010 16:05 #4034
by eslavko
Run in place? was created by eslavko
Hello...
I just try to make new development version of emc2 on my computer.
as many times before I do:
git clone git://git.linuxcnc.org/git/emc2.git emc2-dev
cd emc2-dev
cd src
./autogen.sh
./configure --enable-run-in-place
make
sudo make setuid
cd ..
emc
and try to run my configuration.
The program report error and here is log.
In the 1'st line is something that seems wrong. I (think) I compile with run in place !
(I use 2.5.0~pre in same computer without problems) - Linux Hardy!
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.24-16-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.4
EMC2 - 2.4.3
Machine configuration directory is '/home/slavko/emc2/configs/tester'
Machine configuration file is 'tester.ini'
INIFILE=/home/slavko/emc2/configs/tester/tester.ini
PARAMETER_FILE=stepper.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=emc.nml
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Starting EMC2 TASK program: milltask
Starting EMC2 DISPLAY program: axis
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=5873
Killing task milltask, PID=5996
Cleanup done
Debug file information:
File "/usr/bin/axis", line 55, in <module>
from rs274.interpret import StatMixin
ImportError: cannot import name StatMixin
5873
PID TTY STAT TIME COMMAND
5996
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 395.838657] I-pipe: Domain RTAI registered.
[ 395.838671] RTAI[hal]: <3.6.1> mounted over IPIPE-NOTHREADS 2.0-04.
[ 395.838674] RTAI[hal]: compiled with gcc version 4.2.4 (Ubuntu 4.2.4-1ubuntu3).
[ 395.838680] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 395.838683] PIPELINE layers:
[ 395.838686] dcc15000 9ac15d93 RTAI 200
[ 395.838688] c0383180 0 Linux 100
[ 395.856223] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 395.856832] RTAI[sched]: loaded (IMMEDIATE, UP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 395.856838] RTAI[sched]: hard timer type/freq = 8254-PIT/1193180(Hz); default timing: periodic; linear timed lists.
[ 395.856842] RTAI[sched]: Linux timer freq = 250 (Hz), CPU freq = 2120175000 hz.
[ 395.856845] RTAI[sched]: timer setup = 2010 ns, resched latency = 2688 ns.
[ 395.953159] RTAI[math]: loaded.
[ 396.216659] config string '0x0378'
[ 397.674116] RTAI[math]: unloaded.
[ 397.784611] SCHED releases registered named ALIEN RTGLBH
[ 397.849522] RTAI[malloc]: unloaded.
[ 397.945803] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 397.952770] I-pipe: Domain RTAI unregistered.
[ 397.952790] RTAI[hal]: unmounted.
cd emc2-dev
cd src
./autogen.sh
make
sudo make setuid
cd ..
emc
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMC2 - 2.4.3
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=emc.nml
Starting EMC2...
Cleanup done
5873
5996
07 Sep 2010 20:15 #4039
by BigJohnT
Replied by BigJohnT on topic Re:Run in place?
What command did you use to run EMC with including all paths?
08 Sep 2010 07:31 - 08 Sep 2010 07:50 #4047
by eslavko
Replied by eslavko on topic Re:Run in place?
As I already write:
In my home directory I do:
cd emc2-dev
cd src
./autogen.sh
make
sudo make setuid
cd ..
emc
So I type emc in emc2-dev folder.
I had same thing for 2.5.0~pre release and works.
p.s.
I got no other error until last line (executing emc)
cd emc2-dev
cd src
./autogen.sh
make
sudo make setuid
cd ..
emc
p.s.
Last edit: 08 Sep 2010 07:50 by eslavko. Reason: added p.s.
08 Sep 2010 08:13 #4049
Replied by cmorley on topic Re:Run in place?
looks like you forgot to type:
. scripts/emc-environment
before running emc. You must do this each time you open a new terminal.
08 Sep 2010 10:17 #4051
by BigJohnT
To run a file in a home directory you have to use ./filename or include the complete path or use the envoroment script as Chris pointed out.
So for me to run a RIP on my computer I have to use the command:
Rather than type it in each time I just create a desktop launcher.
/home/john/emc2-dev/scripts/emc /home/john/emc/configs/rip1/mill.config
09 Sep 2010 08:38 #4069
by eslavko
cmorley wrote:
Thanks.
Problem solved
Thanks.
Problem solved
Time to create page: 0.176 seconds
