How build Linuxcnc with xenomai3?
09 Oct 2022 20:05 #253823
by Bari
Replied by Bari on topic How build Linuxcnc with xenomai3?
Franco,
Which hardware did you test RTAI with and what results did you see. Please post any latency test results with CPU used.
Much thanks!
Much thanks!
- fsabbatini
- Thank you received: 49
09 Oct 2022 22:52 #253830
by fsabbatini
Replied by fsabbatini on topic How build Linuxcnc with xenomai3?
Hi Bari,
Hardware is core i5 4gen single board computer,
The issue was not latency but the pc was always running hot , really hot and also with Ethercat master, lots of missed frames and unmatched datagrams.
Changed to xenomai and issues solved, now pc is running cold with 1ms cycle
Regards,
Franco
Regards,
Franco
03 Feb 2023 06:04 #263577
by troy
Replied by troy on topic How build Linuxcnc with xenomai3?
Hi Franco,
Recently I'm going to use a nuc(intel celeron J4125 + intel i210/i211) to build an lcnc controller with EtherCAT, but Supported Ethernet Hardware list on etherlab website does not include intel i210,I was wondering which driver you use to support intel i210,thanks a lot!
link: www.etherlab.org/en/ethercat/hardware.php
Best egards
troy
Best egards
troy
03 Feb 2023 06:20 #263578
Replied by rodw on topic How build Linuxcnc with xenomai3?
I would probably give your NUC a go. I think that network support has been enhanced since that was written.
Follow the sticky in the ethercat section here
03 Feb 2023 08:50 - 23 Feb 2023 15:49 #263584
by troy
you mean your post "Ethercat installation from repositories - how to step by step" in Ethercat section? ok, I will try it.
Regards
troy
Hi rod,I would probably give your NUC a go. I think that network support has been enhanced since that was written.
Regards
troy
Last edit: 23 Feb 2023 15:49 by troy.
- fsabbatini
03 Feb 2023 11:47 #263593
by fsabbatini
Hi! I210 is supported on igb driver my friend
Regards
Franco
Regards
Franco
The following user(s) said Thank You: troy
03 Feb 2023 14:23 #263600
by troy
oh god yes, I found it on intel website ! thanks!Hi! I210 is supported on igb driver my friend
Regards
Franco
06 Feb 2023 03:40 - 23 Feb 2023 15:54 #263790
by troy
Last edit: 23 Feb 2023 15:54 by troy.
- shaying526
04 Sep 2023 03:02 #279778
by shaying526
Replied by shaying526 on topic How build Linuxcnc with xenomai3?
Hi Franco,
Your information is very useful to me
I want to build a LinuxCNC based on Xenomai
But I couldn't find the installation tutorial in 'Getting Started'
Do you have any related installation tutorial links?
Much thanks!
Much thanks!
- SummerLotus
04 Sep 2023 08:21 #279799
by SummerLotus
Replied by SummerLotus on topic How build Linuxcnc with xenomai3?
Hello, do you have the steps to compile and configure xenomai with linuxcnc? When I use --with-realtime=uspace, it always prompts that it is POSIX, not XENOMAI (posix-skin) realtime
Time to create page: 0.162 seconds
