- General
- Installing LinuxCNC
- LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
- snowgoer540
- Topic Author
- Thank you received: 753
07 Sep 2021 12:38 - 12 Jun 2022 13:04 #219847
by snowgoer540
LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion was created by snowgoer540
EDIT:
I split the install thread and the discussion thread to keep the amount of info new users had to wade through to a minimum.
A link back to the install guide is here: forum.linuxcnc.org/9-installing-linuxcnc...red-toward-new-users
Note this guide is not limited to Mesa cards. If you don't have a mesa card, from Section 4 you can skip steps 3 through 5 and also steps 11 through 13. Additionally you can skip Sections 5 and 6.
I can update these sections to make that more clear, thank you for the feedback.
Last edit: 12 Jun 2022 13:04 by snowgoer540.
22 Sep 2021 19:30 #221366
by billykid
Replied by billykid on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
i installed today and sim works however i don't know how to install hostmot2 for my 5i23. I will have become stupid with age
- snowgoer540
- Topic Author
22 Sep 2021 20:37 #221373
by snowgoer540
Replied by snowgoer540 on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
The 5i23 should work fine. I didn’t have to install anything additional to use the 5i25 that drives my table. Are you encountering an error of some kind?
22 Sep 2021 20:44 #221374
by billykid
i don't have hostmot2 i /lib/firmware..I don't remember how to install the package .. i can't find it
- Thank you received: 5959
22 Sep 2021 21:04 #221376
22 Sep 2021 21:14 #221377
by billykid
I understood how it works Tom I cutter and plasma working in closed loop. in this mx19 installation there is no hostmot and I don't remember how to install it.
22 Sep 2021 22:34 #221383
Replied by tommylight on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
Hostmot2 or mesaflash?
Pretty sure hostmot2 is just a copy/paste affair followed by loadrt in .hal, while mesaflash can be found as a binary and started as a normal program or downloaded from git, compiled and installed.
- snowgoer540
- Topic Author
22 Sep 2021 23:30 #221386
by snowgoer540
Mesaflash would make more sense... There are directions to install mesaflash in the docs here.
23 Sep 2021 07:14 #221404
by billykid
I can't make myself understood .. mesaflash is installed my setup has been running for years in wheezy, buster, Mint, etc. now with mx 19 it says hostmot2 is missing in usr / lib / firmware ..
23 Sep 2021 07:32 #221405
by phillc54
Replied by phillc54 on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
This is from the man page for hostmot2:
"The hostmot2 firmware files are supplied by the hostmot2-firmware packages, available from linuxcnc.org and can normally be installed by entering the command "sudo apt-get install hostmot2-firmware-5i23" to install the support files for the 5i23 for example."
linuxcnc.org/docs/devel/html/man/man9/hostmot2.9.html
- General
Time to create page: 0.164 seconds
