Debian 11 Bullseye Repositories
18 Dec 2022 00:33 #259791
by Roguish
Debian 11 Bullseye Repositories was created by Roguish
Does somebody, anybody have the proper and correct repositories for Bullseye Debian 11?
Including of course for LinucCNC ????
Thanks.
Thanks.
- Thank you received: 5959
18 Dec 2022 01:39 #259794
Replied by tommylight on topic Debian 11 Bullseye Repositories
Maybe Rod can help, but in the meantime, i am sure BullsEye does not have LinuxCNC repositories, the BookWorm does, and that is still not official.
18 Dec 2022 08:38 #259805
Replied by rodw on topic Debian 11 Bullseye Repositories
You are better off skipping bullseye in favour of Bookworm as it has linuxcnc included as packages. Bullseye will require building linuxcnc from source but this script automates it:
github.com/joco-nz/lcnc-bullseye-installer
I'd start with the Bookworm alpha ISO cdimage.debian.org/cdimage/unofficial/no...-including-firmware/
then you will find linuxcnc-uspace in synaptic. or
sudo apt install linuxcnc-uspace
30 Dec 2022 17:56 #260557
by Roguish
Replied by Roguish on topic Debian 11 Bullseye Repositories
These work pretty well. took a bit of searching...
deb deb.debian.org/debian/ bullseye main contrib non-free
deb-src deb.debian.org/debian/ bullseye main contrib non-free
deb security.debian.org/debian-security bullseye-security main contrib non-free
deb-src security.debian.org/debian-security bullseye-security main contrib non-free
deb deb.debian.org/debian/ bullseye-updates main contrib non-free
deb-src deb.debian.org/debian/ bullseye-updates main contrib non-free
30 Dec 2022 20:51 #260571
They look like the standard settings for Bullseye.
You will need to build linuxcnc from source as there is no buildbot debs for bullseye.
The following user(s) said Thank You: Roguish
30 Dec 2022 22:36 - 30 Dec 2022 22:36 #260586
by Roguish
Last edit: 30 Dec 2022 22:36 by Roguish.
31 Dec 2022 06:52 #260616
I was not aware of that.
27 Mar 2023 12:53 - 27 Mar 2023 12:54 #267597
by mor
Replied by mor on topic Debian 11 Bullseye Repositories
Any chance for an arm64 build?Rod,
aren't you following what Seb K is doing????
buildbot2.highlab.com
Last edit: 27 Mar 2023 12:54 by mor. Reason: Spelling
27 Mar 2023 18:00 #267616
This is still a work in progress and I'm off on a holiday at the end of this week so nothing much more will happen until after Easter.
See: forum.linuxcnc.org/18-computer/48113-odr...raspberry-pi?start=0
Rod,
Time to create page: 0.164 seconds
