Question....LMDE5 LinuxCNC
- Watchesinc
24 Mar 2023 23:12 #267432
by Watchesinc
Question....LMDE5 LinuxCNC was created by Watchesinc
How do i install? Same as ubuntu through sudo apt? lmde5 Mint. Its a debian version so im assuming it should work.
25 Mar 2023 10:32 #267459
Replied by rodw on topic Question....LMDE5 LinuxCNC
Its much easier with Debian Bookworm... Mint is not up to date with kernels etc.
Start here
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
Start here
- Thank you received: 5959
25 Mar 2023 11:03 #267463
Replied by tommylight on topic Question....LMDE5 LinuxCNC
Is LMDE5 from 2 years ago?
Anyway, i did test all versions of it, they are paunfully slow compared to other Mint versions, so i never used it.
What does
uname -a
Say?
Also what version of python does it use?
Might be able to build/compile LinuxCNC, but i never bothered with it.
What does
uname -a
Say?
Time to create page: 0.109 seconds
