[Solved] Unable to shutdown PC after new installation or kernel upgrade
18 Jun 2023 16:47 #273788
While this is not really a LinuxCNC issue it may be useful for users trying to update older hardware.
If your PC no longer shuts down properly but reboots automatically you can try to modify kernel parameters:
$ sudo nano /etc/default/grub
Modify the line to (ie add xhci_hcd.quirks=270336 to the existing parameters like 'quiet' in this example):
Save and run:
$ sudo update grub
Reboot and see if the shutdown now works. If it does not you can repeat the above with values 8192 & 262144
discussion here:
forums.linuxmint.com/viewtopic.php?t=283503
GRUB_CMDLINE_LINUX_DEFAULT="quiet xhci_hcd.quirks=270336"
Save and run:
$ sudo update grub
discussion here:
18 Jun 2023 16:50 #273789
Replied by Aciera on topic [Solved] Unable to shutdown PC after new installation or kernel upgrade
Worked for me on three different machines after updating from kernel 4.x to 6.x.
Time to create page: 0.075 seconds
