Debian 12 MESA ethernet with wifi configuration
03 Jul 2023 17:58 #274704
by thadwald
Debian 12 MESA ethernet with wifi configuration was created by thadwald
I’m in the process of configuring new computer to upgrade an existing system. Right now I’m stuck at getting network to work with both, the MESA ethernet and wifi LAN.
I set up the MESA ethernet in /etc/network/interfaces as per the Debian 12 installation document. This part works fine. However, after configuring my wifi internet connection (via the GUI tool in the taskbar), the system appears to use the MESA ethernet as the default route, and the wifi connection quits working.
If I try to configure MESA ethernet via the GUI tool, the connection appears to work for a few minutes but then disconnects.
I THINK what I want is to specify the MESA ethernet connection as not providing the default route.
I would also appreciate some clarification as to what the various tools do and if I should be using them. (NetworkManager, networking daemon, etc) I would prefer not having any automatic connections happening on this system.
03 Jul 2023 18:09 #274706
Replied by PCW on topic Debian 12 MESA ethernet with wifi configuration
What address are you using for the real time interface?
Its best to use the 10.10.10.x range for the real time interface
as this does not overlap existing NAT ranges.
03 Jul 2023 20:04 #274711
Replied by rodw on topic Debian 12 MESA ethernet with wifi configuration
Please watch my video
Networking fundamentals is discussed about 16 minutes in
You have to understand this to get the two NICs working.
After that it is easy!
04 Jul 2023 01:20 #274722
by thadwald
Replied by thadwald on topic Debian 12 MESA ethernet with wifi configuration
So you configure all your network interfaces from the gui. The funny thing is that this is the second time around with this specific computer (I messed up something pretty badly and just started again from scratch) and the first time around it worked perfectly. The only thing I did different this time is I unchecked the gnome gui during installation. (Xfce on both)
Yes, I have the MESA board set to 10.10.10.10 and 10.10.10.11 on the nic.
04 Jul 2023 12:32 #274736
by thadwald
Turns out it was an issue with my router.
Thanks.
Thanks.
- Thank you received: 5933
04 Jul 2023 12:50 #274737
Replied by tommylight on topic Debian 12 MESA ethernet with wifi configuration
Mesa board should be wired directly to PC, never through a Hub or Switch or Router or Access point.
04 Jul 2023 14:11 #274745
by thadwald
Yes, that's what I did. Sorry if I wasn't clear enough.
Original issue was that I could get both networks up and working:
The problem with LAN turned out to be a router configuration issue.
There's still an issue with the GUI NetworkManagemer Applet. When I configure the Ethernet connection with static IP address via the GUI, it connects and then disconnects spuriously.
When I configure the same connection via the /etc/network/interfaces file, the connection works without issues. I'm fine with this; I'm just posting here for posterity.
- ethernet connection to MESA baord with static IP set to 10.10.10.2
- wifi connection to LAN
05 Jul 2023 03:28 #274802
by MikeM
Replied by MikeM on topic Debian 12 MESA ethernet with wifi configuration
Make sure you have also set the network connection for your ethernet port to static. Even though I had an IP set in the configs, it was still set for DHCP, which caused a disconnect issue similar to what you described.
Time to create page: 0.287 seconds
