LinuxCNC New user experience
12 Jul 2023 09:31 #275265
by shodan
LinuxCNC New user experience was created by shodan
Hello,
Today I tried linuxcnc for the first time and I want to let you know how it went !
Yesterday I built a 3018pro kit and I was amazed when I made the spindle turn and move around.
Today at the shop I was talking about it with a friend who is also wanting to try the DIY CNC adventure.
He told me he was going to buy one of those simple 500$ DRO style touchscreen computer from amazon or maybe run Mach 3
I told him I thought Mach3 looked stale and boo proprietary software.
I told him there's probably a way to get octoprint or klipper to drive the thing, if he really wanted that 90s DRO chique I mentionned linuxcnc. A topic I had not really thought about in more than 15 years
He was non-plus so I said it looks about the same, I loaded up the webpage on my computer.
I scoured the front page for a view of what it looks like. Something with X Y Z and some numbers like many of our heirloom machines have in the shop.
But the front page is bereft of worthwhile screenshots. We saw the amazon-worker-bot video, I told him, linuxcnc is like a DRO plus gcode playback engine in one. And that there's probably a way to fit it between Kiri:Moto making the gcode and klipper who would interpret the gcode.
then I searched the document page, openned that big ass PDF and found this image
See, it's kind of like octoprint, but less 3dprintery, and we're probably going to use both at once maybe ?
Not sure, I ordered 6x 15mm by 1500 square ways and 3x 16mm ballscrew then we talked milling machine design and drooled at 7x14" mini lathe
While on the hour long drive home I figured, hey maybe I can try linuxcnc, like right now as soon as I step out of my truck !
Some x86 computer, hook it up to that usb port which is probably some usb-serial, maybe these cheap machine all speak a common protocol, probably something real simple too. I bet it's already in linuxcnc, these things have been around for so long !
Got home, grabbed an obsolete chromebox and I have this cheap 5 inch touchscreen, hook that up, download the linuxcnc iso to a stick and boot that up
Here is what happenned nest !
(Oh BTW, I insert an image attachement here and it completely broke this comment's formatting into single non-stop block of text)
(Also BTW, image limit is still just 1.6MB so had to resize down everything) (please at least autoresize server side ?)
It's booting !
touchscreen works !
wifi works !
But can't find a way to pop up the onscreen keyboard for the touchscreen
debian quirkyness, it asks you to save the partition setup, you have to click yes
But you can also click continue ! and then it asks you again.
Maybe the button to continue should just be [YES OVERWRITE THE PARTITION] or something
asking the user about proxies, when there's working internet, not sure that's necessary, fortunately you can just ignore and continue
booting !
that should auto-login by default imho
Tried out the latency thing
Here are the results
machine selection
hmm my board is something vigo
can't find it here
"minimal xyz" yeah, sounds about right
ok hit the 8 images limit here so post, hopefully it doesn't just make me post all this again !
It's booting !
touchscreen works !
wifi works !
booting !
machine selection
can't find it here
12 Jul 2023 09:40 #275266
by shodan
Replied by shodan on topic LinuxCNC New user experience
ok continued !
unfortunately it crashed on start
I hooked up the usb cable to the milling
the touchscreen is glitching out :\
I need an approriate pointing device
So I got the steam controller
I was really really hoping that plugging that in, the X/Y/Z axis on the conroller would start moving the axes but sadly, nothing happened !
Then I realized the linuxcnc program wasn't able to full screen with only 1024x768 of resolution
So I increased the display resolution to 1280x1024
I tried the other programs
I checked out the USB devices
turns out it's the same company that makes the touchscreen as the stepper driver board !
the device name is /dev/ttyUSB0
then I made some midnight bacon and eggs
and started typing this
the sun's out now, I'm going to bed !
12 Jul 2023 09:44 #275267
by shodan
- Thank you received: 5997
12 Jul 2023 10:12 #275271
Replied by tommylight on topic LinuxCNC New user experience
Most probably uses GRBL so you can try one of several free GRBL controllers, bo idea what they are called.
LinuxCNC can do an astonishing amount of stuff, but it does not do control over USB due to latency issues and the fact that controlling a 15 ton machine is extremely time critical.
Klipper might be used after flashing the board, but to much trouble to remove a lot of 3D printery stuff from it.
I am sure someone here made LinuxCNC work with Arduino type boards over USB, search for user DaBit.
And there is Remora being developed exactly for running 3D printer boards with LinuxCNC, but over SPI or Ethernet.
forum.linuxcnc.org/18-computer/44828-rem...em-cnc-board?start=0
Browse through it, there are several 3D printer boards already working.
12 Jul 2023 10:15 #275272
by meister
Replied by meister on topic LinuxCNC New user experience
you main board is not direct compatible with linuxcnc.
you can not use linuxcnc with USB-Boards
12 Jul 2023 19:04 #275291
by shodan
I don't quite know what I want here with this project.
I want to be able to feed a gcode file
have a touchscreen with basic DRO like display
view the gcode, play / stop the gcode
ability to type in gcode for immediate execution
have a cnc pendant for manual control (this is why I had joystick controllers handy, I was hoping to move the axes with regular joystick controls)
This project is gigantic, I'm pleasantly surprised I was able to make it run at all in an evening.
I think what I need is, whenever linuxcnc interpret a line of gcode, I want to pipe this line through a bash script and out the serial port (once I figure out how to talk to the controller. I'm sure it will have an immediate execution mode of gcode, where you just push gcode to it and it runs it in sequence)
My board is apparently made by a chinese company called Vintech, the board is vigo-something, it's also used in laser cutters.
The pendant that comes with it that has an esp32 is called a "vigostick"
When the user in linuxcnc commands a jog, does linuxcnc create the gcode for that and sends it to the decoder engine
Or does manual control output directly to the stepper drivers ?
12 Jul 2023 21:16 #275301
Replied by rodw on topic LinuxCNC New user experience
If you are using a USB board, the Gcode motion controller is on the board so you can send it a file to be run
With Linuxcnc, the motion controller is on the PC. You don't send it a file, instead you open the file and Linuxcnc interprets it and directly controls the motors.
Because Linuxcnc is THE MOTION CONTROLLER it must run in real time (using the PREEMPT_RT patched kernel.)
Nothing over USB is possible to be done in real time due to the underlying protocols so your existing controller is useless (you don't need two motion controllers).
Your computer needs either a Ethernet port or a parallel port to interface to your motors so likely your Chromebook has neither.
Some of your issues mentioned about the experience are nothing to do with Linuxcnc but are part of the Linux operating system installation. Linuxcnc is an application that is run on Linux.
12 Jul 2023 21:28 #275302
by shodan
Is there a way to make linuxcnc log to file each line of gcode as it is executed by the motion engine ?
13 Jul 2023 23:22 #275382
There is a low level structure called state tags which contsins the actual state of the machine right now in real time but it is not the Gcode.
There is not really a way to access this data except by a custom feature in a GUI.
Not really, the code is interpreted into a buffer and dscarded which could be miles ahead of where the actual machine excution is.Is there a way to make linuxcnc log to file each line of gcode as it is executed by the motion engine ?
13 Jul 2023 23:26 #275383
@Shodan
Is the name from "System shock"?
Time to create page: 1.106 seconds
