No Edit or Tool Edit functions
17 Jul 2023 09:32 #275635 by PedroSMS
Hi all,
I think the setup sequence for LinuxCNC, however, the Edit and Edit Tool Table menu commands do nothing. Have I missed a step in the setup sequence?
A brief look at the web - it seems I have to add some lines to the INI file. Can anyone tell me which INI file I have to edit, and what I need to add?
Kind regards
Pedro
17 Jul 2023 10:26 #275638 by Aciera
How did you install LinuxCNC?
Can you please post your config files (ie .ini and .tbl)?
17 Jul 2023 23:45 #275694 by PedroSMS
Thank you for your reply.
I installed it from linuxcnc-2.8.4-buster.iso
File Name: CNCEST-6040.ini
File Size:3 KB
Kind regards
Pedro
18 Jul 2023 04:22 #275712 by Aciera
If you open a terminal and run:
$ linuxcnc
then choose your config from the config picker and try to open the tool table or edit a gcodefile do you get any output in the terminal that may point to the problem?
18 Jul 2023 07:15 - 18 Jul 2023 07:15 #275718 by rmu
Replied by rmu on topic No Edit or Tool Edit functions
From your .ini file it seems you are using QtDragon as your interface. I'm a bit puzzled as at least in my installation there is no menu bar, therefore no Edit menu nor Edit Tool Table menu command. Can you post a screenshot?
To edit tools in qtdragon, it may be necessary to activate and home the machine.
Last edit: 18 Jul 2023 07:15 by rmu.
21 Jul 2023 05:34 #275932 by PedroSMS
It has been a very steep learning curve. Sorry about the wrong INI file I posted earlier...
I have tried many of the GUIs in this system, and I've settled on the qtdragon.
Initially, qtdragon was reporting lots of warning and errors. I ended up reverse-engineering some of the GUI and noticed that quite a few file locations were hardcoded to the developers file system. I changed these locations suit my file system (which included moving some resource files around to suit) - things improved after that.
qtdragon doesn't have an editor, so I installed kate. The two work together well.
And, the Tool Editor works now...
I hope this info helps someone.
Kind regards
Pedro
21 Jul 2023 05:59 #275934 by rmu
I'm pretty sure that there should not be any hardcoded paths specific to a developer system -- would be nice if you could post your findings here or open a github issue.
21 Jul 2023 06:58 #275936 by PedroSMS
Unfortunately, what should be and what is, can be very different...
  <qresource prefix="/home/jim/linuxcnc/configs/qtdragon/">
    <file>images/x_minus_jog_button.png</file>
    <file>images/y_minus_jog_button.png</file>
    <file>images/z_minus_jog_button.png</file>
    <file>images/a_minus_jog_button.png</file>
    <file>images/x_plus_jog_button.png</file>
    <file>images/y_plus_jog_button.png</file>
    <file>images/z_plus_jog_button.png</file>
    <file>images/a_plus_jog_button.png</file>
  </qresource>
I was wondering why some buttons were blank in some of the operating modes/ states..
Kind regards
Pedro
21 Jul 2023 07:41 #275940 by rodw
Replied by rodw on topic No Edit or Tool Edit functions
  </qresource>
Kind regards
Pedro
Can you post in the qtvcp section and include the file name. I'm sure Chris will get it fixed in no time.
23 Jul 2023 23:32 #276116 by PedroSMS
They are in a few places. Just use your favourite file searcher, I installed and used kfind.
Search /usr/share/qtvcp for files containing "/jim/"
Kind regards
Pedro
Time to create page: 0.167 seconds
