Making the Probe status visible on the GUI
17 Jul 2023 09:42 #275637
by PedroSMS
Making the Probe status visible on the GUI was created by PedroSMS
Hi all,
Is there a way to make the Probe status visible on the GUI?
Kind regards
Pedro
Kind regards
Pedro
17 Jul 2023 18:48 #275669
Replied by rodw on topic Making the Probe status visible on the GUI
Use qt_dragon GUI and it's done for you
17 Jul 2023 22:34 #275688
Replied by cmorley on topic Making the Probe status visible on the GUI
If you are not using QtDragon, please tell us which you are using, so we can answer more precisely.
17 Jul 2023 23:32 - 17 Jul 2023 23:33 #275693
by PedroSMS
Replied by PedroSMS on topic Making the Probe status visible on the GUI
Thank you for your reply.
I have the qtdragon GUI working, but the probe status does not change when I touch the probe.
Using the ./parport_CD00.demo program, I can see the pin (P12) state change.
I have setup stepconf to P12 = Probe_in.
BTW, each time I use stepconf it changes the GUI back to axia, do you know how to stop that?
Kind regards
Pedro
Kind regards
Pedro
Last edit: 17 Jul 2023 23:33 by PedroSMS.
18 Jul 2023 00:08 #275695
I depending on what version of linuxcnc, qtdragon may have a HAL pin that must be connected.
Can you post your config files and what version of linuxcnc are you using?
18 Jul 2023 01:03 #275698
by PedroSMS
I'm sorry, I'm on the very steep edge of the learning curve.
I was using (I think it's called) Axis.
Kind regards
Pedro
Kind regards
Pedro
18 Jul 2023 01:15 #275699
by PedroSMS
Thank you for your reply @cmorley.
I'm using LinuxCNC 2.8 with Debian Buster.
Kind regards
Pedro
Kind regards
Pedro
18 Jul 2023 06:43 #275717
Ok you would need to make a VCP panel with an LED to represent the probe state.
Usually pyvcp is used with AXIS to make simple VCP. Gladevcp and qtvcp can also be used if you have a more complicated panel in mind.
20 Jul 2023 09:31 #275873
by PedroSMS
Hi all,
After trying a few different GUIs, I'm focused on the QtDragon.
I'm attempting to do some fine tuning. Probe - the input is configured, and it operates as expected with G38.2.
I want to get the GUI "Probe LED" to operate. The instructions say (in the HAL section)-
Kind regards
Pedro
Does anyone know the syntax, and which file this needs to be entered into?This input pin should be connected to indicate probe state.
qtdragon.led-probe
Kind regards
Pedro
20 Jul 2023 09:50 #275876
Must be a new feature so I'll have to add it. Something like this
Where lcec.0.3.in-06 is my EtherCAT input pin the probe is attached to.
net probe-sig <= lcec.0.3.in-06
net probe-sig => motion.probe-input
net probe-sig => qtdragon.led-probe
Time to create page: 0.278 seconds
