Update to uspace
18 Jul 2023 00:29 - 18 Jul 2023 00:37 #275696 by PedroSMS
Update to uspace was created by PedroSMS
Hi all,
The Updating LinuxCNC documents says :
If you see (as above) -rt- in the kernel name then you are running the preempt-rt kernel and should install the "uspace" version of linuxcnc. You should also install uspace for "sim" configs on non-realtime kernels
The instructions following does not give the Repositories details for the uspace version. I have had a few guesses, but no luck.
Does anyone know these details?
I'm using Debian Buster.
Kind regards
Pedro
Last edit: 18 Jul 2023 00:37 by PedroSMS. Reason: formatting
18 Jul 2023 01:59 #275700 by cornholio
18 Jul 2023 02:05 #275701 by PedroSMS
Replied by PedroSMS on topic Update to uspace
Thank you for your reply.
I have been there, but can't find a reference to 'uspace'
Kind regards
Pedro
18 Jul 2023 02:08 - 18 Jul 2023 02:08 #275702 by cornholio
Replied by cornholio on topic Update to uspace
2.8 branch (stable)
Buster (arch: amd64, i386, armhf)
uspace: realtime with RT-Preempt, and simulation
deb buildbot.linuxcnc.org/ buster 2.8-rtpreempt
deb-src buildbot.linuxcnc.org/ buster 2.8-rtpreempt
rt-preempt is uspace
Last edit: 18 Jul 2023 02:08 by cornholio.
18 Jul 2023 02:12 #275703 by PedroSMS
Thanks again for your reply.
So, the instructions that are published (as shown above) are incorrect?
Kind regards
Pedro
18 Jul 2023 02:22 - 18 Jul 2023 02:22 #275704 by cornholio
No they are correct.
The buildbot info table gives the repo info for rt-preeempt. My last post was a copy and paste from the buildbot page.
To quote again
If you installed from one the linuxcnc distributed ISO's you should not have to worry about adding the repo info. Unless you are trying to upgrade from 2.7 then that's a different kettle of fish.
Last edit: 18 Jul 2023 02:22 by cornholio.
18 Jul 2023 02:43 #275708 by PedroSMS
Given my kernel name is 4.19.0.21-rt-amd64, and the Update instructions say:
Can you see the confusion?
Kind regards
Pedro
18 Jul 2023 02:58 #275709 by cornholio
The buildbot page is pretty clear
18 Jul 2023 03:26 - 18 Jul 2023 03:27 #275710 by PedroSMS
Have you read the Update instructions?
linuxcnc.org/docs/2.8/html/getting-start...dating-linuxcnc.html
Kind regards
Pedro
Last edit: 18 Jul 2023 03:27 by PedroSMS.
18 Jul 2023 03:50 #275711 by cornholio
Seems simple, to tell the truth I've been building my own packages for Linux Mint, but the instructions seem pretty clear and concise.
Time to create page: 0.099 seconds
