Error install LinuxCNC to Debian 12
23 Jul 2023 03:58 #276057
by smplc
Replied by smplc on topic Error install LinuxCNC to Debian 12
I changed the boot order to first Ubuntu and second Debian to allow Ubuntu Secure Boot. The Grub is ignored and Ubuntu automatically boots up.
Visa versa the Grub automatically displays its menu. Debian boots okay but Ubuntu does not when Secure Boot enabled.
Disabling Secure Boot as foregoing the Ubuntu boots from the Grub.
I guess it's not a requirement to configure Ubuntu in the Grub but suppose it'd be convenient if available in the menu and would try making the configuration.
sudo cat /boot/grub/device.map
(hd0) /dev/disk/by-id/nvme-Samsung_SSD_970_EVO_Plus_500GB_S58SNM0W323594T
(hd1) /dev/disk/by-id/ata-CT500MX500SSD1_2307E6AF11B5
ls /dev/disk/by-id -lt
lrwxrwxrwx 1 root root 15 Jul 22 10:49 nvme-eui.002538533191bca8-part1 -> ../../nvme0n1p1
lrwxrwxrwx 1 root root 15 Jul 22 10:49 nvme-eui.002538533191bca8-part2 -> ../../nvme0n1p2
lrwxrwxrwx 1 root root 15 Jul 22 10:49 nvme-Samsung_SSD_970_EVO_Plus_500GB_S58SNM0W323594T-part1 -> ../../nvme0n1p1
lrwxrwxrwx 1 root root 15 Jul 22 10:49 nvme-Samsung_SSD_970_EVO_Plus_500GB_S58SNM0W323594T-part2 -> ../../nvme0n1p2
lrwxrwxrwx 1 root root 13 Jul 22 10:49 nvme-eui.002538533191bca8 -> ../../nvme0n1
lrwxrwxrwx 1 root root 13 Jul 22 10:49 nvme-Samsung_SSD_970_EVO_Plus_500GB_S58SNM0W323594T -> ../../nvme0n1
sudo fdisk -l
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 1050623 1048576 512M EFI System
/dev/nvme0n1p2 1050624 976771071 975720448 465.3G Linux filesystem
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 465.8G 0 disk
├─sda1 8:1 0 512M 0 part /boot/efi
├─sda2 8:2 0 464.3G 0 part /
└─sda3 8:3 0 976M 0 part [SWAP]
nvme0n1 259:0 0 465.8G 0 disk
├─nvme0n1p1 259:1 0 512M 0 part
└─nvme0n1p2 259:2 0 465.3G 0 part
sudo parted -l
Model: ATA CT500MX500SSD1 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 538MB 537MB fat32 boot, esp
2 538MB 499GB 499GB ext4
3 499GB 500GB 1023MB linux-swap(v1) swap
Model: Samsung SSD 970 EVO Plus 500GB (nvme)
Disk /dev/nvme0n1: 500GB
Sector size (logical/physical): 512B/512B
Disk Flags:
1 1049kB 538MB 537MB fat32 EFI System Partition boot, esp
2 538MB 500GB 500GB ext4
grub> cat (hd0,2)/etc/issue #hd0,gpt2
Debian GNU/Linux 12 \n \l
grub> cat (hd1,2)/etc/issue #hd1,gpt2
Ubuntu 22.04.2 LTS \n \l
I see cat /boot/grub/device.map is (hd0) /dev/disk/by-id/nvme-Samsung_SSD_970_EVO_Plus_500GB_S58SNM0W3235694T but grub> cat (hd1,2)/etc/issue .
Is then?
grub> set root=(hd1,2)
grub> linux /boot/vmlinuz-3.13.0-29-generic root=/dev/nvme0n1p2
grub> initrd /boot/initrd.img-3.13.0-29-generic
grub> boot
sudo fdisk -l
lsblk
sudo parted -l
Disk Flags:
Disk Flags:
Is then?
grub> boot
23 Jul 2023 09:33 #276059
Replied by rodw on topic Error install LinuxCNC to Debian 12
I would probably bite the bullet and just reinstall Deban 12.1 netinstall from the very first link here.
www.debian.org/download
The 2.9 docs have been updated with the updated download URLS to 12.1 (eg that link). The changes have just been pushed but it will take a while to get deployed on the website.
Debian has a chapter on UEFI (Secure Boot) wiki.debian.org/SecureBoot#What_is_UEFI.3F
I think using Bookworm and its 6.1 kernel will solve any UEFI/Secure Boot issues as a lot of work with UEFI went into the 6.1 kernel
REF: www.phoronix.com/news/Linux-6.1-EFI-Features
I have not experienced any UEFI issues with bookworm and I have deliberately tested a UEFI install recently.
24 Jul 2023 17:08 #276157
by smplc
Thanks for the link. I installed Debian 12.1 and see it may require the GNOME Extension Manager to install desktop icons.
The Grub that came with Debian 12.1 still doesn't Secure Boot Ubuntu. Debian 12.1 Secure Boots okay from the Grub. Ubuntu 22.04.2 Secure Boots okay from it boot loader (AMI). It appears the Grub menu detects Ubuntu but requires manual configuration. Maybe the Ubuntu shouldn't be configured to the Grub that if I ever remove the SDD and boot it from another computer. I'd rather not configure Ubuntu to the Grub if it interferes with the boot loader (AMI) on the NVMe that boots Ubuntu.
25 Jul 2023 06:25 #276201
I don't believe you will get secure boot working across both distros until Ubuntu adopts a later kernel that has better support for UEFI.
I just give Bookworm the full SSD volume to itself.
- Thank you received: 5983
27 Jul 2023 02:15 #276344
Replied by tommylight on topic Error install LinuxCNC to Debian 12
Moved the posts that did not belong here to "Other languages > Albanian".
Thank you for your patience.
Time to create page: 0.119 seconds
