Compiling linuxcnc 2.9 help on mint (SOLVED)
13 Aug 2023 03:22 - 13 Aug 2023 17:04 #277793
by fabled523
Compiling linuxcnc 2.9 help on mint (SOLVED) was created by fabled523
After somehow successfully installing the preempt_rt kernel I have been working at compiling linuxcnc 2.9 on linux mint.
All dependencies have been installed, attached is what I get after trying to compile.OS is mint 21.2, kernelĀ 5.10.180-rt89-rc1, i5 2500 8gb ram.
I also tried just installing linuxcnc 2.8.4 from a .deb file but i get a message saying dependency is not satisfiable: python (>=2.7). I have python 2.7.18-3 installed, not sure what the issue there is.
Any help would be appreciated.
EDIT: Recompiling with no-docs worked! Thank you very much!
Last edit: 13 Aug 2023 17:04 by fabled523. Reason: Solution Found
13 Aug 2023 04:05 #277796
Replied by Aciera on topic Compiling linuxcnc 2.9 help on mint
To build 2.9 from the github source (only that is currently possible on mint) use a fresh installation of mint install the dependencies. Leave the python alone! If you start fiddling with with python versions you're going to loose your mind.
If you still have problems I strongly recommend using Debian Bookworm and installing Linuxcnc from the Package manager.
13 Aug 2023 04:25 - 13 Aug 2023 04:30 #277798
by cornholio
Replied by cornholio on topic Compiling linuxcnc 2.9 help on mint
When you cd into the debian directory (before building packages )run configure with theI have 2 machines running Mint 21.2 Victoria and this works.
This is what I have on my machine:
no-docs option
xxxxxx@xxxxxx:~$ cat /etc/lsb-release
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=21.2
DISTRIB_CODENAME=victoria
DISTRIB_DESCRIPTION="Linux Mint 21.2 Victoria"
xxxxxx@xxxxxx:~$ python --version
Python 3.10.12
Last edit: 13 Aug 2023 04:30 by cornholio.
- Thank you received: 5994
13 Aug 2023 11:00 #277813
Replied by tommylight on topic Compiling linuxcnc 2.9 help on mint
If you want to give Debian 12 BookWorm a try, use the Mate Desktop Environment, it is the same thing Mint uses.
Or XFCE if on an older PC.
