LinuxCNC on Debian Bookworm
26 Sep 2023 12:33 - 26 Sep 2023 12:34 #281645
by holziCNC
LinuxCNC on Debian Bookworm was created by holziCNC
Hello everybody,I am facing the following fault during installation. I have reinstalled Python, so that may be a possible cause. Do you have any solutions for the problem?
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
linuxcnc-uspace : Depends: libboost-python1.67.0 but it is not installable
Depends: libpython2.7 (>= 2.7) but it is not installable
Depends: libreadline5 (>= 5.2) but it is not installable
Depends: python (>= 2.7) but it is not installable
Depends: python (< 2.8) but it is not installable
Depends: python:any (< 2.8) but it is not installable
Depends: python:any (>= 2.7~) but it is not installable
Depends: python2.7-tk but it is not installable
Depends: python2.7-glade2 but it is not installable or
python-glade2 but it is not installable
Depends: python2.7-numpy but it is not installable or
python-numpy but it is not installable
Depends: python2.7-imaging but it is not installable or
python-imaging but it is not installable or
python-pil but it is not installable
Depends: python2.7-imaging-tk but it is not installable or
python-imaging-tk but it is not installable or
python-pil.imagetk but it is not installable
Depends: python-gtksourceview2 but it is not going to be installed
Depends: python-gst-1.0 but it is not installable
Depends: python-xlib but it is not installable
Depends: python-gtkglext1 but it is not installable
Depends: python-configobj but it is not installable
Recommends: linuxcnc-doc-en but it is not going to be installed or
linuxcnc-doc
Recommends: python-pyqt5 but it is not installable
Recommends: python-pyqt5.qsci but it is not installable
Recommends: python-pyqt5.qtopengl but it is not installable
Recommends: python-pyqt5.qtsvg but it is not installable
Recommends: python-pyqt5.qtwebkit but it is not installable
Recommends: python-opencv but it is not installable
Recommends: python-rsvg but it is not going to be installed
Recommends: python-dbus.mainloop.pyqt5 but it is not installable
Recommends: python-espeak but it is not installable
Recommends: pyqt5-dev-tools but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
linuxcnc-doc
Last edit: 26 Sep 2023 12:34 by holziCNC.
- Thank you received: 5945
26 Sep 2023 15:04 #281654
Replied by tommylight on topic LinuxCNC on Debian Bookworm
How are we supposed to help you, you never mentioned what are you trying to install, and therein lies the issue, you are trying to install and older version of LinuxCNC that still uses Python 2.7 !!!
What version of BookWorm, there are several, what Desktop Environment, how are you trying to install whatever you are are trying to install, etc
26 Sep 2023 19:18 - 26 Sep 2023 19:19 #281660
Replied by rodw on topic LinuxCNC on Debian Bookworm
Python 2.7 was deprecated in Debian 11 and Bookworm is Debian 12.
Linuxcnc 2.8 uses Python 2.7. Therefore, you cannot run Linuxcnc 2.8 or earlier on bookworm.
You must run Linuxcnc 2.9 or higher which use Python 3.xx
In the stickies in this section, there is an ISO of bookworm that includes 2.9
Or you can follow the instructions in the v 2.9 getting started docs to install on an existing Debian 12 installation
Last edit: 26 Sep 2023 19:19 by rodw.
The following user(s) said Thank You: tivoi
