- General
- Installing LinuxCNC
- dpkg-shlibdeps: Error: no dependency information found for /usr/lib/libmodbus.so
31 Oct 2023 20:48 - 03 Nov 2023 09:33 #284216
by bkt
Unfortunately for my SO need to install version of Lcnc2.9 with python 2.7 ..... build package obtain these error ....
dpkg-shlibdeps: Error: no dependency information found for /usr/lib/libmodbus.so.5 (used by debian/linuxcnc-uspace/usr/bin/vfs11_vfd)
but not find any docs about libmodbus to install on mint 19.03 .... and if build a new version of libmodbus from libmodus git repo, not know where put it for make happy "dpkg-buildpackage -b -uc" command .... run in place install work perfect.
Warning: Spoiler!
dpkg-shlibdeps: Avviso: package could avoid a useless dependency if debian/linuxcnc-uspace-xenomai/usr/lib/libuspace-xenomai.so.0 was not linked against libxenomai.so.0 (it uses none of the library's symbols)
dpkg-shlibdeps: Errore: no dependency information found for /usr/lib/libmodbus.so.5 (used by debian/linuxcnc-uspace/usr/bin/vfs11_vfd)
Hint: check if the library actually comes from a package.
dh_shlibdeps: dpkg-shlibdeps -Tdebian/linuxcnc-uspace.substvars -l/debian/linuxcnc-uspace/usr/lib debian/linuxcnc-uspace/usr/bin/halui debian/linuxcnc-uspace/usr/bin/halcmd debian/linuxcnc-uspace/usr/bin/linuxcnc_module_helper debian/linuxcnc-uspace/usr/bin/halmeter debian/linuxcnc-uspace/usr/bin/svd-ps_vfd debian/linuxcnc-uspace/usr/bin/panelui debian/linuxcnc-uspace/usr/bin/io debian/linuxcnc-uspace/usr/bin/vfdb_vfd debian/linuxcnc-uspace/usr/bin/thermistor debian/linuxcnc-uspace/usr/bin/mb2hal debian/linuxcnc-uspace/usr/bin/xhc-hb04 debian/linuxcnc-uspace/usr/bin/halscope debian/linuxcnc-uspace/usr/bin/schedrmt debian/linuxcnc-uspace/usr/bin/hy_gt_vfd debian/linuxcnc-uspace/usr/bin/linuxcncrsh debian/linuxcnc-uspace/usr/bin/halstreamer debian/linuxcnc-uspace/usr/bin/shuttle debian/linuxcnc-uspace/usr/bin/halsampler debian/linuxcnc-uspace/usr/bin/wj200_vfd debian/linuxcnc-uspace/usr/bin/linuxcncsvr debian/linuxcnc-uspace/usr/bin/hy_vfd debian/linuxcnc-uspace/usr/bin/rtapi_app debian/linuxcnc-uspace/usr/bin/genserkins debian/linuxcnc-uspace/usr/bin/linuxcnclcd debian/linuxcnc-uspace/usr/bin/gs2_vfd debian/linuxcnc-uspace/usr/bin/inivar debian/linuxcnc-uspace/usr/bin/milltask debian/linuxcnc-uspace/usr/bin/halrmt debian/linuxcnc-uspace/usr/bin/rs274 debian/linuxcnc-uspace/usr/bin/vfs11_vfd debian/linuxcnc-uspace/usr/bin/classicladder debian/linuxcnc-uspace/usr/bin/iov2 debian/linuxcnc-uspace/usr/bin/motion-logger debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/maj3.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/and2.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hal_lib.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hm2_7i43.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/toggle.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/debounce.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/lcd.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/streamer.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/near.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/weighted_sum.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/conv_bit_u32.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/scope_rt.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/modmath.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/orient.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/integ.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/abs_s32.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/simple_tp.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hal_parport.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/corexy_by_hal.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/spindle_monitor.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/rotarydeltakins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/logic.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/gray2bin.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hal_ppmc.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/match8.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hm2_test.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/boss_plc.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/carousel.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/threads.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/mesa_pktgyro_test.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/thc.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/conv_u32_float.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/scarakins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/genhexkins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hostmot2.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/flipflop.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/corexykins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/eoffset_per_angle.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/bldc.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/stepgen.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/moveoff.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/conv_bit_float.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/conv_float_u32.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/clarke3.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/threadtest.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/scarakins10.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/5axiskins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/biquad.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/bitslice.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/clarkeinv.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/sim_matrix_kb.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/lincurve.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/ilowpass.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/lut5.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/mux4.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/encoder.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/bldc_hall3.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/sum2.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/mesa_7i65.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/setsserial.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/ddt.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/scorbot-kins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/counter.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/edge.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/sampler.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/timedelta.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/multiswitch.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/minmax.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/rosekins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/toggle2nist.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/scarakins4.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/siggen.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/bitwise.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/joyhandle.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/at_pid.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/bin2gray.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hal_pi_gpio.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/conv_float_s32.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/xyzac-trt-kins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/axistest.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/offset.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/not.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/lowpass.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/limit1.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/limit2.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/updown.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hypot.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/conv_u32_bit.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/motmod.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/constant.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/knob2float.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/mux16.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/comp.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hm2_7i90.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/thcud.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/tristate_float.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/classicladder_rt.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/pentakins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hm2_spi.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/mult2.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/select8.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/watchdog.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/tripodkins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/abs.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/encoder_ratio.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/clarke2.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/timedelay.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/feedcomp.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/conv_s32_u32.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/differential.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/demux.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/estop_latch.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/sim_encoder.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/sim_axis_hardware.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/rotatekins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/scale.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/tristate_bit.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/mux2.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/charge_pump.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/pwmgen.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/serport.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/conv_s32_float.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/oneshot.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/sample_hold.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/conv_u32_s32.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/maxkins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/limit3.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/or2.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/xyzbc-trt-kins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/ohmic.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/matrix_kb.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hm2_rpspi.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/gearchange.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/sim_home_switch.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/sim_parport.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/steptest.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/scarakins11.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/blend.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/max31855.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/invert.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/deadzone.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/mux_generic.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/conv_s32_bit.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/conv_bit_s32.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/multiclick.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/histobins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hm2_eth.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/sphereprobe.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/wcomp.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hal_gm.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/pumakins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/gantry.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/genserkins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hal_bb_gpio.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/latencybins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/xhc_hb04_util.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/sim_spindle.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/supply.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/trivkins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/time.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/plasmac.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/lineardeltakins.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/hm2_pci.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/mux8.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/message.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/xor2.so debian/linuxcnc-uspace/usr/lib/linuxcnc/modules/pid.so debian/linuxcnc-uspace/usr/lib/libpyplugin.so.0 debian/linuxcnc-uspace/usr/lib/libcanterp.so.0 debian/linuxcnc-uspace/usr/lib/liblinuxcnchal.so.0 debian/linuxcnc-uspace/usr/lib/tcltk/linuxcnc/hal.so debian/linuxcnc-uspace/usr/lib/tcltk/linuxcnc/linuxcnc.so debian/linuxcnc-uspace/usr/lib/librs274.so.0 debian/linuxcnc-uspace/usr/lib/libnml.so.0 debian/linuxcnc-uspace/usr/lib/liblinuxcncini.so.0 debian/linuxcnc-uspace/usr/lib/python2.7/dist-packages/gcode.x86_64-linux-gnu.so debian/linuxcnc-uspace/usr/lib/python2.7/dist-packages/_togl.x86_64-linux-gnu.so debian/linuxcnc-uspace/usr/lib/python2.7/dist-packages/minigl.x86_64-linux-gnu.so debian/linuxcnc-uspace/usr/lib/python2.7/dist-packages/linuxcnc.x86_64-linux-gnu.so debian/linuxcnc-uspace/usr/lib/python2.7/dist-packages/_hal.x86_64-linux-gnu.so debian/linuxcnc-uspace/usr/lib/python2.7/dist-packages/rotarydeltakins.x86_64-linux-gnu.so debian/linuxcnc-uspace/usr/lib/python2.7/dist-packages/lineardeltakins.x86_64-linux-gnu.so debian/linuxcnc-uspace/usr/lib/libposemath.so.0 returned exit code 255
dh_shlibdeps: Aborting due to earlier error
debian/rules:102: recipe for target 'binary-arch' failed
make: *** [binary-arch] Error 2
dpkg-buildpackage: Errore: fakeroot debian/rules binary subprocess returned exit status 2
[/spoiler]
Last edit: 03 Nov 2023 09:33 by bkt.
03 Nov 2023 09:32 #284422
by bkt
Replied by bkt on topic dpkg-shlibdeps: Error: no dependency information found for /usr/lib/libmodbus.so
solution: install libmodbus 3.1.6 and use ldconfig ... these give you access to dependancy folder info as request from buildpackage ... than during dpkg-checkbuild.... if not install again libodbus-dev from repo ....
thats all folks !!
thats all folks !!
- General
Time to create page: 0.071 seconds
