XHC-WHB04B-6 & pncconf
09 Nov 2023 20:56 #284972
by poesel
XHC-WHB04B-6 & pncconf was created by poesel
to get the pendant mentioned in the subject running, I need to change my .ini file. The same file also warns me that pncconf will overwrite any changes I make to this file if I ran pncconf again.
Question: is pncconf something you only run once, and you do all the later changes in the file, or is there a better way to handle this?
Thanks.
Thanks.
- Thank you received: 5945
09 Nov 2023 21:59 #284980
Replied by tommylight on topic XHC-WHB04B-6 & pncconf
PncConf is usually used once to make a "as close as possible" configuration for the machine, although it is very good at it and when there are no "special features" it will make perfectly working configs.
You can use it to edit configs at any time, but it does overwrite the main hal and ini files, so if you add other features, keep those in a separate hal file and add the entry for it in the ini file. This way if you do edit with PncConf, you only need to add that line to ini file.
The following user(s) said Thank You: poesel
12 Nov 2023 17:45 #285185
by poesel
Replied by poesel on topic XHC-WHB04B-6 & pncconf
I just found the file 'custom.hal' which is automatically included in the .ini that pncconf creates. So adding the necessary commands for my pendant there makes it 'pncconfig safe'.
Time to create page: 0.250 seconds
