- General
- Installing LinuxCNC
- Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
17 Nov 2023 17:29 #285757
Replied by PCW on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
I would expect Mesaflash and hm2_spi to work since they use the generic SPI device driver
(as long as that's accessible and correct), but hm2-rpspi may well need to be updated
to match whatever SPI hardware the RPI5 has.
17 Nov 2023 20:03 #285773
Replied by rodw on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
Also read today that the graphics drivers for the Pi5 won't b ereleased until kernel 6.8. I don't think that will be a big issue for CNC.
17 Nov 2023 20:42 #285775
by cornholio
Replied by cornholio on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
As I mentioned in my woes post I had to force mesaflash to 8 bit word length as 32 bit wasn't communicating.
27 Nov 2023 19:24 #286634
by JackRay
Replied by JackRay on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
Hello,
I'm sorry but I didn't understand, how to install in a simple way this last version of linuxcnc on raspberry pi4 with last version of the real time kernel .
can someone help me?
27 Nov 2023 21:34 #286640
by cornholio
28 Nov 2023 01:31 #286650
Andy tested this image for the Pi5 and found it worked ok except image colour depth was lacking.
drive.google.com/file/d/1H_q0Ra-27ZDOhqu...x1f/view?usp=sharing
This is just a variation of whats on the Downloads page for the 4b
28 Nov 2023 11:15 #286690
by elovalvo
Replied by elovalvo on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
I think many posts in this thread are completely unrelated to the topic I started it with.
My idea was to compare the performance of the Raspbian Bookworm (and not the Debian) on Pi4 and Pi5....
28 Nov 2023 11:19 #286691
ITs difficult for users to compare the products until they have a robust installation method for the pi5. But it has been reported latency is much improved.I think many posts in this thread are completely unrelated to the topic I started it with.
05 Mar 2024 23:03 - 06 Mar 2024 19:49 #295266
by pgf
Replied by pgf on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
[/code][/code]The results are definitely surprising [code][code]Regarding this... is it understood why the latency was so much better in the RPi 5 test, than the RPi 4? Is this purely a result of improved processor performance, or is there some other underlying reason? (And, has that result been reproduced?) Unless I'm misunderstanding, I think that latency is quite a bit better than I currently get on my 10 y.o. AMD PC, which implies I could potentially replace it (and its parallel port) directly with an RPi 5 and its gpio pins. Which I confess excites me a bit. :-) paul
Last edit: 06 Mar 2024 19:49 by pgf. Reason: text was incorrectly... tried again. and again.... argh. it's getting worse. I give up.
06 Mar 2024 00:26 #295273
by cornholio
The OP has describe a robust installation method within the opening couple of posts. Having tested both methods for the RPi5, the Raspbian OS based method appears to be the better setup.
- General
Time to create page: 0.219 seconds
