Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
31 Dec 2023 18:51 - 31 Dec 2023 19:06 #289441
Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images was created by rodw
Hi guys, could you guys with the PI's please test these images for me and provide some feedback
These are refreshes of my earlier 2.9.1 images.
They both use the latest PREMPT_RT 6.1.69 kernel, and Debian Bookworm
Raspberry Pi 4b/400
drive.google.com/file/d/1Bzx_PqRqdJVTMPl...cDX/view?usp=sharing
Raspberry PI 5
https://drive.google.com/file/d/1HBXliMQE-OvU0PQPYEOK3OqJz0-CTO5K/view?usp=sharing
Also, those of you with the Pi5, have you had any issues with sound. One user reported he had no sound but the HDMI output is a bit poblematic. The images do include pulseaudio.
For initial login credentials, and initial configuration, please refer to the download page
linuxcnc.org/downloads/
Raspberry Pi 4b/400
Raspberry PI 5
Last edit: 31 Dec 2023 19:06 by rodw.
The following user(s) said Thank You: cauldron_boy
- der hobbyist
01 Jan 2024 09:59 #289463
by der hobbyist
Replied by der hobbyist on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
I get an error if I try to install the image for a Pi 5.
Best and a happy new year
01 Jan 2024 11:56 #289465
Replied by rodw on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
COuld you translate that to English please? I will report it to the upstream guysHi,
- der hobbyist
01 Jan 2024 13:05 #289469
by der hobbyist
here is the translation:
The input file is not a valid disk image.
The file size 4723000000 bytes is not a multiple of 512 bytes
01 Jan 2024 18:13 #289489
It appears that there is something about our image that the Rpi Imager does not like.
The guys are working on it.
Could you please try burning with Balena Etcher? etcher.balena.io/
This burnt and validated the image for me.
- der hobbyist
01 Jan 2024 18:22 #289491
by der hobbyist
Yes, balena works for me,too.
01 Jan 2024 18:31 #289495
It seems that we are using a slightly different compression method that the PI imager does not like.
Great! Please test it out a bit and give me some feedbackYes, balena works for me,too.
- der hobbyist
01 Jan 2024 20:27 #289508
by der hobbyist
I have tested it a bit on my lathe with gmoccapy. So far so good. With my old iso I had some latency errors they are gone. The audio error on raspberry pi 5 persists.
And I can't move/rotate the gcode viewer with touchscreen.
02 Jan 2024 16:38 #289576
by scotth
Replied by scotth on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
Balena works well.
Screen resolution works so much better than anything I have seen so far. Jitter is good and sim looks smooth.
Problems, I have no sound, no Wi-Fi, no network manager and no update manager.
Thank you for all the work.
Scott
Scott
02 Jan 2024 20:55 #289601
Scott,
Please read the Linuxcnc downloads page.
Typing: sudo menu-config
allows you to set wifi and locale etc.
Configuring fixed ip address etc for ethernet card, can be done manually as described if you type: man hm2_eth
We removed networkmanger I had added it in and latency suffered on the pi4b
If you really need to use it, you can install synaptics: sudo apt install synaptic
I prefer to search for the package names in Debian Package search packages.debian.org/index
and use sudo apt install package-name
When you say you don't have sound, this is a known issue, one of the upstream guys was going to review that for me as its a limitation of their installer. Their first priority was to fix the compression settings so it can be installed with rpi-imager.
I don't think it will be wise to use sudo apt upgrade becasue we have a custom built PREEMPT_RT kernel we have built from source using a kernel version not in Debian Bookworm..
Note the ethercat repos are installed if you want to go that way.
