Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
- der hobbyist
02 Jan 2024 22:32 - 02 Jan 2024 22:59 #289612
by der hobbyist
Replied by der hobbyist on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
I found another small bug. Then I change a tool the icons of the desktop menu become visible (see picture below).
Last edit: 02 Jan 2024 22:59 by der hobbyist.
03 Jan 2024 04:05 #289634
Replied by rodw on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
That is nothing to do with the installation process. I can't help. Report in the correct GUI sectionHi,
03 Jan 2024 10:02 - 03 Jan 2024 10:03 #289644
by cornholio
That's normal behaviour for the bottom panel in Debian for XFCE (for amd64 & arm64) when you move the mouse over the area where the panel would be no matter the application you are using, if you right click on the panel you can change the properties. Not a bug & does not require reporting.
Replied by cornholio on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
Last edit: 03 Jan 2024 10:03 by cornholio.
03 Jan 2024 10:18 #289646
Aah, now I know what you were looking at. an XFCE feature
- cauldron_boy
06 Jan 2024 16:09 #289978
by cauldron_boy
Replied by cauldron_boy on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
Installed on a Pi5 8Gb.
Running great with a Mesa 7i76e
11 Jan 2024 09:32 #290411
by Calysto
Replied by Calysto on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
I have an older image installed on my PI, with 2.9.1. The normal update/upgrade procedure won't help. Can I upgrade to this 'image'?
11 Jan 2024 09:40 #290413
Install the 2.9.2 image from the downloads page
If its a Pi 5, this image is likely better but you need o use Balena Etcher to burn it to an SD card as the rpi imager does not like it.
drive.google.com/drive/folders/1NfRV8bho...3VXtN?usp=drive_link
This has been fixed upstream but I have not had time to rebuild it
11 Jan 2024 10:02 - 11 Jan 2024 13:54 #290414
by Calysto
Hmm... then I have to re-install all the rest.... might do that later...
Pi4
Pi4
Last edit: 11 Jan 2024 13:54 by Calysto.
15 Jan 2024 14:19 - 16 Jan 2024 17:47 #290759
by U2fletch
Replied by U2fletch on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
I have a Pi 400 and the image loads fine. I have sound, and can confirm that it runs great on my setup. Had a minor hiccup with my Mesa 7i96s board. I could ping the board at address 10.10.10.10, but when I started LinuxCNC I got the "temporarily unavaliable" error. Had to go configure my network settings. Once that was set everything works great. Thanks!
Last edit: 16 Jan 2024 17:47 by U2fletch. Reason: Had wrong image loaded
31 Jan 2024 22:25 #292108
by itai
Replied by itai on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
I want to use Raspberry PI 4 + LinuxCNC-RIO (Tangoboard) with SPI connection.
How can I enable SPI (using the IO pins) with the LinuxCNC image?
How can I disable the automatic screen lock?
Thanks,
-- Itai
Thanks,
-- Itai
Time to create page: 0.322 seconds
