Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
- Wierzbowski
08 Feb 2024 18:24 #292898
by Wierzbowski
Replied by Wierzbowski on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
hi, could You please make step-by-step video guide for newbies how to setup raspberry pi 400/4b in order to controll cnc machine?
- Thank you received: 4154
08 Feb 2024 20:10 - 08 Feb 2024 20:11 #292903
Download the iamge
Burn do a SD card using Balena Etcher (free download windows and linux)
Boot the pi using the SD card
Log in with username/password cnc/cnc
open a terminal
type: sudo menu-config
and set up your wifi if required, locale and time zone etc. You can also change your password.
After that you have a computer with linuxcnc installed so simply refer to the docs on the LinuxCNC web site. There is a specific gpio driver for the Pi that is documented there. There is also a pi specific Mesa card but I would recommend you use a Mesa Ethernet card for future flexibility.
You can also install ethercat if you want to use it but thats not a beginners path
sudo apt install linuxcnc-ethercat (from memory)
Replied by rodw on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
I can't cos I don't have a pi. But do this:hi, could You please make step-by-step video guide for newbies how to setup raspberry pi 400/4b in order to controll cnc machine?
Download the iamge
open a terminal
Last edit: 08 Feb 2024 20:11 by rodw.
The following user(s) said Thank You: Wierzbowski
- xenon-alien
16 Apr 2024 11:13 #298382
by xenon-alien
Replied by xenon-alien on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
Hello.
Sorry that I'm asking 2nd time, but...
How can I change the resolution, orientation (+touch) and make it sound?
I have a 10.1" IPS Touch display with resolution 1920x1200 @60 Hz + audio speakers.
But there is no sound, the resolution is only 1920x1080, no possibility to rotate the screen.
Is it possible to make it work?
On a Windows system the display works fine. (even tried on the Orange Pi PC with Armbian and it almost worked)
My config.txt file
My config.txt file
arm_64bit=1
initramfs initrd.gz followkernel
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
framebuffer_width=1920
framebuffer_height=1200
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=87
hdmi_cvt=1920 1200 60 5 0 0 0
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
# camera
#start_x=1
#gpu_mem=128
# automatically load overlays for detected cameras
#camera_auto_detect=1
# automatically load overlays for detected DSI displays
#display_auto_detect=1
# uncomment to overclock: https://www.tomshardware.com/how-to/overclock-any-raspberry-pi
#arm_freq=
#gpu_freq=
#core_freq=
#over_voltage=
#force_turbo=1
# uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# additional overlays and parameters are documented /boot/overlays/README
# enable audio (loads snd_bcm2835)
dtparam=audio=on
# enable uart
enable_uart=0
# disable wifi and bluetooth
#dtoverlay=disable-wifi
#dtoverlay=disable-bt
#dtoverlay=pi3-disable-wifi
#dtoverlay=pi3-disable-bt
# remove test rainbow
disable_splash=1
# disables the warning overlays
#avoid_warnings=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[pi4]
# enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-kms-v3d
#dtoverlay=vc4-fkms-v3d
max_framebuffers=2
arm_boost=1
max_usb_current=1
- elovalvo
- Thank you received: 127
16 Apr 2024 11:28 #298385
by elovalvo
forum.linuxcnc.org/9-installing-linuxcnc...i-5?start=190#298380
Replied by elovalvo on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
Hello.
- cncmiljc
03 Aug 2024 13:56 #306872
by cncmiljc
Replied by cncmiljc on topic Linuxcnc 2.9.2 for Raspberry Pi 4 & 5 images
Could anyone help, I made the image for the pi4 following the image on the official page, but it doesn't have the area for ethernet configuration, how can I solve this problem?
03 Aug 2024 16:57 #306884
I am not sure if the pi is supported in their repos for Debian 12 at all
Also I doubt that a linuxcnc-ethercat driver is built for the pi either
Right now your option is to build from source
I have raised an issue with Ethercat to explore a solution for this.
The current 2.9.2 image needs updating to 2.9.3 but we no longer install Ethercat repositories for the Raspberry pi.Could anyone help, I made the image for the pi4 following the image on the official page, but it doesn't have the area for ethernet configuration, how can I solve this problem?
- cncmiljc
03 Aug 2024 17:51 #306886
by cncmiljc
In my case, it would be ethernet, I need the configuration area for the IP/Gateway address, that way, I can study the connection with ethernet cards.
03 Aug 2024 17:59 #306887
read the comments on the downloads page. menu-config should do it for you.
12 Aug 2024 07:02 #307541
updated for Linuxcnc 2.9.3
Newer kernel 6.6.44
Better screen support for the Pi5
Now includes ethercat repos. Following the sticky in th eethercat section to install/
Pi 5 Image drive.google.com/file/d/1iwQpbMoNdI6wnv7...MyZ/view?usp=sharing
Pi4 Image drive.google.com/file/d/1Fg2CPTezUyrRFrO...ytT/view?usp=sharing
Newer kernel 6.6.44
The following user(s) said Thank You: Aciera, flyingbrick
12 Aug 2024 07:12 #307542
Replied by rodw on topic Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
The first post has been updated to include images for 2.9.3.
The Pi 5 is tested and working.
Any feedback about the Pi4 would be appreciated
Time to create page: 0.170 seconds
