Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
- Moutomation
- Thank you received: 11
21 Jan 2025 05:32 #319551
by Moutomation
Replied by Moutomation on topic Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
I think linuxcnc only works on 2-4-8gb,right?
- Thank you received: 426
21 Jan 2025 05:51 #319553
Replied by Cant do this anymore bye all on topic Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Ok, the 16GB board was only released at the beginning of the year, maybe you were thinking of the 8GB boards rod. So I don't think it's a Linuxcnc issue but a kernel issue.
What I would suggest you do is load up an sd card with an Raspberry Pi image, boot it up and relay the output of
I'm thinking it may require a 6.13.x or 6.12.x kernel. As the 6.6.y branch is active that keren may work but can't certain.
uname -aI'm thinking it may require a 6.13.x or 6.12.x kernel. As the 6.6.y branch is active that keren may work but can't certain.
- Moutomation
21 Jan 2025 05:55 #319554
by Moutomation
rpi-5-debian-bookworm-6.6.44-rt39-arm64-ext4-2024-08-12-2032.img this image worked
21 Jan 2025 06:01 #319555
ok cool.
I've just built a new image could you give it a whirl if it doesn't work I'll say that its not recommended for the 5 with 16GB only tested with 4GB.
drive.google.com/file/d/1MEgxQ1IrdI2hnnw.../view?usp=drive_link
- Moutomation
21 Jan 2025 06:22 #319556
by Moutomation
ok I'm trying right now
21 Jan 2025 06:51 #319559
Much appreciated Sir.
- Moutomation
21 Jan 2025 07:37 - 21 Jan 2025 07:38 #319565
by Moutomation
No image appeared on the screen, not working
Last edit: 21 Jan 2025 07:38 by Moutomation.
21 Jan 2025 08:15 #319568
Ok I’ll make a note of that.
Thanks for testing.
Thanks for testing.
The following user(s) said Thank You: Moutomation
- foxkid
15 Mar 2025 16:20 #324027
by foxkid
Replied by foxkid on topic Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Thank you for the images. There are a few kernel/driver changes I'll be working around, but the experience was super easy.
Backstory: I tried to upgrade my successful installation, and the pi wouldn't boot, giving the "missing firmware" error. I copied my existing linuxcnc config files using another Linux system. I installed your image on windows. I copied the config onto the new SD card. It booted and nearly all was well.
Thank you.
Thank you.
- Ultrakurz
21 Apr 2025 14:16 #326834
by Ultrakurz
Replied by Ultrakurz on topic Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Hello gentlemen !
Im a Newby and want to run a CNC-mill with a Mesa 7i76E and a Rpi 5.
I have read the thread and think a RPI 5 with 8 GB will be the right choice for
bookworm and the mesa. The 16 GB RPI5 won't work or is there any kind of news ?
The freason for the question is that i have to buy a RPI but which one is the best opinion and why ?
Can you help me ?
Thanks a lot
Ultrakurz
Can you help me ?
Thanks a lot
Ultrakurz
Time to create page: 0.314 seconds
