RPI 4 apt update warning
02 Jan 2024 20:52 #289599
by dskinne6
RPI 4 apt update warning was created by dskinne6
I am getting the following warning when doing a sudo apt-get update on my RPI 4 running bookworm:Hit:5 www.linuxcnc.org bookworm InRelease
Reading package lists... Done
W: Skipping acquire of configured file '2.9-rt/source/Sources' as repository 'www.linuxcnc.org bookworm InRelease' does not seem to provide it (sources.list entry misspelt?)I installed linuxcnc 2.9.2 according to linuxcnc.org/docs/2.9/html/getting-start...lling_on_raspbian_12
uname -a: Linux raspberrypi 6.1.0-rpi7-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (2023-11-24) aarch64
The following linuxcnc entries in my sources.list:
deb [arch=amd64,arm64 signed-by=/usr/share/keyrings/linuxcnc.gpg] www.linuxcnc.org/ bookworm base 2.9-uspace 2.9-rt
deb-src [arch=amd64,arm64 signed-by=/usr/share/keyrings/linuxcnc.gpg] www.linuxcnc.org/ bookworm base 2.9-uspace 2.9-rt
Do I need to update my sources.list?
02 Jan 2024 21:01 #289603
Replied by rodw on topic RPI 4 apt update warning
You can ignore that warning.
Linuxcnc sources can be found in the folder /etc/apt/sources.list.d which is the correct method to addd custom repos.
For some reason there is an additional loacation specified by Andy, the release manager that generates that warning
The following user(s) said Thank You: dskinne6
