Linuxcnc-uspace-dev_2.9.2 DEB package. RTAI
04 Mar 2024 21:18 #295162
by COFHAL
Linuxcnc-uspace-dev_2.9.2 DEB package. RTAI was created by COFHAL
Where can I get the linuxcnc-uspace-dev_2.9.2 DEB package. RTAI
- Thank you received: 5946
04 Mar 2024 21:38 #295163
Replied by tommylight on topic Linuxcnc-uspace-dev_2.9.2 DEB package. RTAI
Do you mean the linuxcnc-dev for RTAI kernel?
linuxcnc.org/dists/bookworm/2.9-rt/binar...-dev_2.9.2_amd64.deb
The following user(s) said Thank You: COFHAL
04 Mar 2024 21:51 #295165
Replied by andypugh on topic Linuxcnc-uspace-dev_2.9.2 DEB package. RTAI
sudo apt-get install linuxcnc-dev
Should do the trick.
If it doesn't let me know and I will try to work out what's going wrong.
04 Mar 2024 23:36 #295170
by COFHAL
Replied by COFHAL on topic Linuxcnc-uspace-dev_2.9.2 DEB package. RTAI
Yes.
05 Mar 2024 14:39 #295232
by COFHAL
Thank, but It cannot be installed because the headers for kernel 5.4.258-rtai-amd64 are missing.
05 Mar 2024 20:27 #295254
sudo apt-get install linux-headers-5.4.258-rtai-amd64
(We keep them as a package here: www.linuxcnc.org/dists/bullseye/base/binary-amd64/ )
You can find the exact package name with
sudo apt-cache search linux-headers*
05 Mar 2024 21:37 #295261
by COFHAL
Ok, thank solved
Time to create page: 0.338 seconds
