opening Gcode in AXIS release 2.9.2
11 Mar 2024 14:28 #295637
by partec
opening Gcode in AXIS release 2.9.2 was created by partec
now was the moment for me to try out the current LinuxCNC_2.9.2-amd64.hybrid.iso
I have already noticed great progress on some important parts that I like to use, thank you very much to everyone who made it!
When reading Gcode into Axis I have a small problem with 'utf-8' codec, both in a live session or after a new installation
It's about the special characters around the comments, what should I do best?
- Thank you received: 5946
11 Mar 2024 15:09 #295638
Replied by tommylight on topic opening Gcode in AXIS release 2.9.2
Set locale to UTF-8 in Linux, search for:
Debian change locale
The following user(s) said Thank You: partec
11 Mar 2024 16:26 #295649
by partec
Replied by partec on topic opening Gcode in AXIS release 2.9.2
thanks for the encouragement
root@debian:/home/eruepe# localectl
System Locale: LANG=de_CH.UTF-8
LANGUAGE=de_CH:de
VC Keymap: (unset)
X11 Layout: us
X11 Model: pc105
X11 Layout setting was set to 'us' for some reason, that doesn't fit together
LANGUAGE=de_CH:de
VC Keymap: (unset)
X11 Layout: us
X11 Model: pc105
11 Mar 2024 18:21 #295668
by partec
X11 Layout: us
tommylight,
how can I change X11 layout, please?
tommylight,
11 Mar 2024 20:56 #295681
Wait, what are you using to generate the gcode?
Seems to be the issue with gcode, not LinuxCNC, so can you try some code generated by another program/software like Inkscape or Image2gcode (included with LinuxCNC, just open a jpg file) ?
12 Mar 2024 08:46 #295723
by partec
have reinstalled
I'm not entirely sure whether my iso is completely integer because 'lvm2-udeb' was also searched for and wasn't found
I'll still verify it, but System Locale is now correct
root@se:~# localectl
LANGUAGE=de_CH:de
VC Keymap: (unset)
X11 Layout: ch
X11 Model: pc105
root@se:~#
(ngc file edited Line from remote and axis reloadable)
(Messingplatte vertikal 25mm)
G54 G90 G17 G61
(Tasche schlichten d 2.8mm)
G00 X110.423 Y-117.333 Z80
G00 Z26
G01 Z24.4 F34.5
G01 Y-117.433 F88.5
G01 X118.123
At the moment I should be able to get along and thank you very much for the tireless moderator help always here!
LANGUAGE=de_CH:de
VC Keymap: (unset)
X11 Layout: ch
X11 Model: pc105
root@se:~#
G54 G90 G17 G61
G00 Z26
G01 Z24.4 F34.5
G01 Y-117.433 F88.5
G01 X118.123
Time to create page: 0.176 seconds
