MD5 Checksum doesn't match although downloaded with zsync
22 Mar 2024 12:33 - 22 Mar 2024 12:35 #296539
by reneas
MD5 Checksum doesn't match although downloaded with zsync was created by reneas
As the title says I downloaded the newest release with:
The output was:
After downloading I ran the MD5 Checksum tool and got:
which is different from the checksum at here
which says it should be
Also when I tried to run the whole thing on my PC I could boot into live session but when I started the installer it would just get stuck on a black screen and not do a thing forever.
zsync http://www.linuxcnc.org/iso/LinuxCNC_2.9.2-amd64.hybrid.iso.zsync
The output was:
#################### 100.0% 1854.5 kBps DONE
No relevent local data found - I will be downloading the whole file. If that's not what you want, CTRL-C out. You s
hould specify the local file is the old version of the file to download with -i (you might have to decompress it wi
th gzip -d first). Or perhaps you just have no data that helps download the file
downloading from http://www.linuxcnc.org/iso/LinuxCNC_2.9.2-amd64.hybrid.iso:
-------------------- 0.0% 12.3 kBps
#################### 100.0% 7389.8 kBps DONE
verifying download...checksum matches OK
used 0 local, fetched 3472884144
d541b51f02ecc6f07fe652faa0fc4a2b LinuxCNC_2.9.2-amd64.hybrid.iso
md5sum: 1815aceaac0e7861747aa34d61846e79
Last edit: 22 Mar 2024 12:35 by reneas. Reason: formatting
25 Mar 2024 09:11 #296695
by reneas
Replied by reneas on topic MD5 Checksum doesn't match although downloaded with zsync
Okay at least the installation worked now after resetting the BIOS to default settings. Still wondering why the Checksum didn't match...
- Thank you received: 5942
25 Mar 2024 09:31 #296701
Replied by tommylight on topic MD5 Checksum doesn't match although downloaded with zsync
Thank you for reporting back.
25 Mar 2024 14:12 #296719
by JT
Replied by JT on topic MD5 Checksum doesn't match although downloaded with zsync
You're comparing different iso checksums so they won't be the same. The docs are listing md5sum linuxcnc-2.9.2-amd64.iso not the hybrid iso and they also state if you use zsync checking is not needed.
JT
JT
30 Mar 2024 23:48 - 30 Mar 2024 23:59 #297245
by steveb48
Replied by steveb48 on topic MD5 Checksum doesn't match although downloaded with zsync
Ah, I'm having a similar problem. I followed the instructions here ((linuxcnc.org/docs/stable/html/getting-st...etting-linuxcnc.html) and the link downloads the hybrid iso. Not using zsync (on macOS). The listed checksums don't match probably for the same reason listed above. Is there another link I should be downloading from or is there a set of hybrid checksum? I did try to add zsync to my LinuxCNC machine and just do the download there but I get a file not found from FTP.
Thanks,
Steve
Thanks,
Steve
Last edit: 30 Mar 2024 23:59 by steveb48.
31 Mar 2024 16:06 - 31 Mar 2024 16:23 #297292
by steveb48
Replying to myself.
It turns out there's a zsync port for macOS on Homebrew.
I was able to download using:
zsync www.linuxcnc.org/iso/LinuxCNC_2.9.2-amd64.hybrid.iso.zsync
Note "http" not "https".
The download link produces LinuxCNC... and the instructions call for linuxcnc....
The dd instructions for macOS have the source file at root where the linux instructions start at the current directory.
I think I have it all sorted. We'll find out tomorrow when the new computer arrives.
Last edit: 31 Mar 2024 16:23 by steveb48.
Time to create page: 0.105 seconds
