Run linuxcnc On RPi 4 through SSH
29 Mar 2024 03:37 #297057
by xylotex
Run linuxcnc On RPi 4 through SSH was created by xylotex
I installed: debian-bookworm-6.1.54-rt15-arm64-ext4-2023-11-17-1731.img.xz
on the RPi4 and using normal Keyboard and monitor, linuxcnc comes up fine.
When I try linuxcnc through SSH I get the following (using Axis as display and Putty with X11 forwarding Enabled along with Xming on my PC):
X Error of failed request: GLXUnsupportedPrivateRequest
Major opcode of failed request: 143 (GLX)
Minor opcode of failed request: 17 (X_GLXVendorPrivateWithReply)
Serial number of failed request: 764
Current serial number in output stream: 764
Do I need to update some conf files on the PI? or...?
Thanks,
Jeff
Thanks,
Jeff
29 Mar 2024 10:03 #297086
Replied by andypugh on topic Run linuxcnc On RPi 4 through SSH
are you using ssh -X ? Maybe also try ssh -Y
(Putty might hide this detail from you, I don't know how to configure the authentication in Putty)
30 Mar 2024 00:30 #297174
by xylotex
Replied by xylotex on topic Run linuxcnc On RPi 4 through SSH
I did try :ssh -Y This email address is being protected from spambots. You need JavaScript enabled to view it.
after logging in, when starting linuxcnc basically saying
_tkinter.TclError: no display name and no $DISPLAY environment variable
I tried an older version:linuxcnc-2.8.2-buster.iso
and got that working, so something must have changed since that and the linuxcnc-2.9.1-bookworm-rpi4.img.xz (and later) versions
31 Mar 2024 11:16 #297271
You might find some clues here: stackoverflow.com/questions/37604289/tki...environment-variable
One promising comment says "If you connect from Win machine to remote server via putty you have to install Xming to forward X11."
31 Mar 2024 21:12 #297307
by jst
Replied by jst on topic Run linuxcnc On RPi 4 through SSH
I did this successfully using X410 on Windows and LinuxCNC on the RPi.
But I would have to look up the exact configuration.
02 Apr 2024 06:33 #297420
by elovalvo
Replied by elovalvo on topic Run linuxcnc On RPi 4 through SSH
05 Apr 2024 08:27 - 23 Apr 2024 01:31 #297626
by Plauiead
Replied by Plauiead on topic Run linuxcnc On RPi 4 through SSH
X410 on Windows and LinuxCNC on the Raspberry Pi were the tools I needed to accomplish the task.
However, I'd need to verify the precise setup. geometry dash lite
Last edit: 23 Apr 2024 01:31 by Plauiead.
Time to create page: 0.153 seconds
