Ethercat HAL driver
20 Sep 2021 07:54 - 20 Sep 2021 07:57 #221175
by udoS
Replied by udoS on topic Ethercat HAL driver
@yrodriguez
This board makes the RPi3/4 a slave. Works great. Easy to setup.
Gives you a max of 128 Bytes Space.
Best thing: Great support ! "Andrea Bausano"
www.bausano.net/en/hardware/ethercat-e-a...t-and-raspberry.html
Best regds. udo
Best regds. udo
Last edit: 20 Sep 2021 07:57 by udoS.
- yrodriguez1234
20 Sep 2021 12:33 #221188
by yrodriguez1234
Replied by yrodriguez1234 on topic Ethercat HAL driver
Thanks udo.
Will be possible a hal component for LCNC that convert a raspberry pi 4 in a ethercat slave.
20 Sep 2021 13:24 - 20 Sep 2021 13:24 #221190
by db1981
Replied by db1981 on topic Ethercat HAL driver
hello,
you can't build an ethercat slave without an licensed hardware chip or Asic firmware by beckhoff. You can code your own master, but not legaly a slave.
For this you can by boards/Chips from Beckhoff ET1100 / ET1815 or licensed ic's at Infinion / Microchip etc...
if you need an high counts of pieces them cost only a few dollars...
for prototypes or homebuildings i would by an ethercat evaluation Kit and then use Soes (simple open ethercat slave) or buy an ready to use rasppi or arduino expansion board.
getting your own slave running with linuxcnc ethercat then, is the smallest step.... (coding own driver or config manual in the conf xml.)
Last edit: 20 Sep 2021 13:24 by db1981.
20 Sep 2021 13:29 - 20 Sep 2021 13:30 #221191
by udoS
@yrodriguez
1. You have data on the RPi4;
2. You want this data make available to PC-Ethercat-Master and ultimately to Lcnc ;
SO: some how you need the RPi to become a slave ; I told you one way to do that ;
Then you can read the data through the master into the HAL.
For that you need a component to attach the slave to the Etherlab Master, but that is available.
Hope that helped or else please give more info's / details about your setup or intensions.
best rgds udo
best rgds udo
Last edit: 20 Sep 2021 13:30 by udoS.
20 Sep 2021 13:36 #221192
by udoS
@db1981
the Bausano slave is a legal expansion board for the raspi.
They are building a whole range of low cost ethercat cnc boards.
Just have a look
Just have a look
20 Sep 2021 13:50 #221194
by udoS
Now there is also a soft-plc available running on linux-PC and RPi3/4 that has a Ethercat Master.
From there it just takes a rt-plugin (shared memory with semaphore) to have any data from plc into HAL;
Nothing illegal about it.
Best rgds. udo
Best rgds. udo
- yrodriguez1234
20 Sep 2021 14:12 - 20 Sep 2021 17:57 #221196
by yrodriguez1234
I going yo explane that a have mount.
1. PC with LCNC 2.8 and ethercat Master working.
2. A raspberry pi 4 with LCNC 2.8 and ethercat Master working.
My problem is when a conect de PC with rpi through ethercat, the PC does not reconize de rpi as ethercat slave.
I need reconize rpi 4 like slave to send information from a hal component on rpi yo a hal component on PC
I readed SOES from Github but I don't know how use it to solve my question.
Thanks.
Thanks.
Last edit: 20 Sep 2021 17:57 by yrodriguez1234.
20 Sep 2021 14:29 #221200
by db1981
you can only talk beetween ec master over an bridge interface, but that hat not be done yet on linuxcnc.
To get your pi as an slave you need an extra piece of hardware, (like the bausano udoS showed, it has an ethercat stamp on board) .
But to get your information from linuxcnc on your pi to the ec-slave board, you have to code an own component / interface driver.
If your use case is not realtime critical i would implement my own tcp communication layer in an c-comp.
- yrodriguez1234
20 Sep 2021 14:53 #221202
by yrodriguez1234
In my case is not realtime critical I could test your c-comp.
20 Sep 2021 14:55 #221203
by udoS
There is an other problem I see here.
If your RPi has the ethercat master running then there is NO free NIC.
So you need additional hardware one or the other way. Wether it's the slave HAT or TCP HAT.
What is that setup anyway. Two interconnected robots. Working together. Sounds interesting.
best rgds. udos
best rgds. udos
Time to create page: 0.173 seconds
