asd-a2-e ... lcec driver?
03 Oct 2023 20:11 - 03 Oct 2023 20:12 #282200
by jjdege
Replied by jjdege on topic asd-a2-e ... lcec driver?
I believe the lcec_deasda driver is crucial for creating the pins in LCNC
here is another similar link, it was useful to me
forum.strojirenstvi.cz/viewtopic.php?t=25321
Hi
Hi
Last edit: 03 Oct 2023 20:12 by jjdege.
The following user(s) said Thank You: bkt
04 Oct 2023 10:22 #282263
by bkt
Replied by bkt on topic asd-a2-e ... lcec driver?
using asda-soft I upoload new parameter as suggested on github link posted by jjdege ..... so I able to read on terminal:
so seems all was ok about register and CoE cia402 ..... but using axis gui and generic driver I obtain nothing .... so think was about sync and probabily because not use deasda driver .... but not sure about .... if someone can explain me was perfect ... some link for self learning is perfect too.
:~$ ethercat upload -p 0 -t int32 0x6064 00
0x0011f851 1177681
:~$ ethercat upload -p 0 -t int16 0x6041 00
0x0000 0
:~$ ethercat upload -p 0 -t int16 0x6040 00
0x0004 4
04 Oct 2023 10:42 #282265
by bkt
so now I try complete version of github guide .... and I use siitool for name changing .... plus I insert in my xml file that row, so from teminal:
from xml:
and error from axis gui:
that was not as expected ..... prefer something other like .... pin xxxx not find instead ... seems means symply slave type was not see
:~$ ethercat slaves -v
=== Master 0, Slave 0 ===
Device: Main
State: PREOP
Flag: +
Identity:
Vendor Id: 0x000001dd
Product code: 0x10305070
Revision number: 0x02040608
Serial number: 0x00000000
DL information:
FMMU bit operation: no
Distributed clocks: yes, 32 bit
DC system time transmission delay: 0 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0* MII up open yes - 1457545430 0 0
1 MII up open yes 1 1457551430 6000 1540
2 N/A down closed no - - - -
3 N/A down closed no - - - -
Mailboxes:
Bootstrap RX: 0x0000/0, TX: 0x0000/0
Standard RX: 0x1000/128, TX: 0x10c0/128
Supported protocols: CoE
General:
Group: Servo Drive
Image name:
Order number: ASDA-A2-E
Device name: ASDA-A2-E
CoE details:
Enable SDO: yes
Enable SDO Info: yes
Enable PDO Assign: yes
Enable PDO Configuration: yes
Enable Upload at startup: yes
Enable SDO complete access: no
Flags:
Enable SafeOp: no
Enable notLRW: no
Current consumption: 0 mA
from xml:
<slave idx="7" type="ASDA-A2-E" name="3A1">
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="-25000"/>
</slave>
Debug file information:
Can not find -sec DISPLAY -var INTRO_GRAPHIC -num 1
Can not find -sec DISPLAY -var INTRO_TIME -num 1
Note: Using POSIX realtime
[color=#e74c3c]lcec_conf: ERROR: Invalid slave type ASDA-A2-E[/color]
lcec_conf: ERROR: Parse error at line 4: parsing aborted
04 Oct 2023 11:16 #282269
by jjdege
in lcec_conf the name of the servo is DeASDA and must be reported in the .xml file,
it is not <slave idx="7" type="ASDA-A2-E" name="3A1">
but <slave idx="7" type="DeASDA" name="3A1">
See if it goes wrong
04 Oct 2023 11:36 #282271
by bkt
try before see your reply .... and obtain the right error instead the wrong one ...
04 Oct 2023 11:41 #282273
by bkt
A BIG POINT TO KNOW BEFORE: dowload ASDA_soft for first and go to "tuning" menu before any action. If not is not possible to moove motor for every positiv test. After parameter save repeat these tuning operation.
04 Oct 2023 11:53 #282275
by bkt
not understand how to set PDO's ....
04 Oct 2023 15:56 #282298
by jjdege
sorry, I can't follow you
04 Oct 2023 17:18 #282302
by bkt
I read lcec_deasda.c file.... seems was set for CSV only and not possible set for CSP mode ....
there are not code for pdo idx=1600 and pdo idx 1a00 ..... so only cyclic position mode is possible with these drive .... ok .... previously think was possible set somethings .... my error
It would be interesting to create the drive for position mode with PDO 1600 and 1A00 ... even just to learn.
static ec_pdo_entry_info_t lcec_deasda_in[] = {
{0x6041, 0x00, 16}, // Status Word
{0x606C, 0x00, 32}, // Current Velocity
{0x6064, 0x00, 32}, // Current Position
{0x2511, 0x00, 32} // external encoder
static ec_pdo_entry_info_t lcec_deasda_out[] = {
{0x6040, 0x00, 16}, // Control Word
{0x60FF, 0x00, 32} // Target Velocity
static ec_pdo_info_t lcec_deasda_pdos_out[] = {
{0x1602, 2, lcec_deasda_out}
static ec_pdo_info_t lcec_deasda_pdos_in[] = {
{0x1a02, 4, lcec_deasda_in}
static ec_sync_info_t lcec_deasda_syncs[] = {
{0, EC_DIR_OUTPUT, 0, NULL},
{1, EC_DIR_INPUT, 0, NULL},
{2, EC_DIR_OUTPUT, 1, lcec_deasda_pdos_out},
{3, EC_DIR_INPUT, 1, lcec_deasda_pdos_in},
{0xff}
04 Oct 2023 17:27 #282303
by bkt
IN SUMMARY:
lcec_deasda driver admit to work only in Cyclic synchronous velocity mode --- WARNING NO OTHER MODE ---
For First dowload ASDA_soft on windows, connect motor to drive, connect usb to asda drive, connect and than go to Tuning for autotuning of motor .... after these you can moove something and see encoder feedback (not possible whitout these step).
After go to link shared from jjdege: github.com/liuzq71/LinuxCNC-ASDA-A2-E/blob/master/README.md Build siitool from source $ git clone github.com/synapticon/siitool.git $ make$ sudo make install Write EEPROM for ASDA-A2-E nat@linuxcnc:~/siitool/delta$sudo ethercat -p0 sii_write Delta-asda.binnat@linuxcnc:~/siitool/delta$sudo ethercat rescannat@linuxcnc:~/siitool/delta$sudo ethercat slave Config ASDA-A2-E Driver Use ASDA_soft write parameter from file ASDA-A2-E Servo_Ethercat.par
AFTER you can use delta asda-a2-E only in Cyclic synchronous velocity mode --- WARNING NO OTHER MODE ---
Time to create page: 0.721 seconds
