Getting errors while installing etherlab master
12 Apr 2024 13:05 #298066
by Mehta_123
Getting errors while installing etherlab master was created by Mehta_123
E: Unable to locate package linux-headers-4.19.71-rt24-v7l
E: Couldn't find any package by glob 'linux-headers-4.19.71-rt24-v7l'
E: Couldn't find any package by regex 'linux-headers-4.19.71-rt24-v7l'
I want to install etherlab master on raspberry pi while installing get above errors please provide any solutions for Above errors
- Thank you received: 5959
12 Apr 2024 16:47 #298080
Replied by tommylight on topic Getting errors while installing etherlab master
Did you do
sudo apt update
Before trying to install?
Just getting it out of the way as i do not use RPI.
sudo apt update
12 Apr 2024 20:57 #298124
Replied by rodw on topic Getting errors while installing etherlab master
Way out of date
Install linuxcnc 2.9 from the official ISO and install ethercat from the provided and installed repositories. Refer to the sticky in the ethercat section
15 Apr 2024 06:58 #298270
by Mehta_123
Replied by Mehta_123 on topic Getting errors while installing etherlab master
Thanks for the reply !!
I did sudo apt update and upgrade.
Hi Rod, I was hoping for your reply since I followed your steps for installing Ethercat. I have successfully installed and able to detect slaves as well.
Also I have created udev rule so that I don't have to give permission everytime, but everytime I reboot or start rpi4 "/dev/EtherCAT0" vanishes !!
I have found solution from the last post of "Ethercat installation from repositories":
root@raspberrypi:~# /usr/sbin/ethercatctl stop
rmmod: ERROR: Module ec_master is in use by: ec_genet
root@raspberrypi:~# rmmod ec_genet
root@raspberrypi:~# /usr/sbin/ethercatctl start
After following this commands I am able to see "/dev/EtherCAT0", can you please help me with this so that I don't have to follow above commands?
Thanks !!
Thanks !!
15 Apr 2024 07:24 #298272
I suspect you missed setting upa udev rule as outlined in the instructions
15 Apr 2024 08:40 - 15 Apr 2024 08:56 #298274
by Mehta_123
Nope, I have followed these three steps:
Did I miss something?
Thanks !!
sudo geany /etc/udev/rules.d/99-ethercat.rules
KERNAL=="EtherCAT[0-9]", MODE="0777"
sudo udevadm control --reload-rules
Thanks !!
Last edit: 15 Apr 2024 08:56 by Mehta_123.
Time to create page: 0.094 seconds
