Matsuura Mc 500v2 retrofit.
  • skunkworks
  • Topic Author
  • Moderator
  • Moderator
10 years 8 months ago #70526 by skunkworks
Matsuura Mc 500v2 retrofit. was created by skunkworks
We purchased this machine a couple years ago. It is an early 80's model with a mx1 control. The servo and spindle drives work just fine so we are planning on re-using everything that we can.
Going with mesa (of course)
We lucked out an all the axis encoders are 5v differential (some had 12v)
The setup is going to be
computer -> Ethernet -> 7i80 -> 7i48 V V -> 24 port opto22 board V V -> 7i44 -> 7i73 V V -> 7i69 -> 2x 24 port opto22 boards
That will give me
-6 axis of analog out/differential encoders
-72 i/o
-panel interface MPG's and i/o
-expandable
Currently We just started and only have worked on getting a basic spindle encoder installed. It doesn't have one and we would like to be able to rigid tap.
We are using gear teeth sensors to do the quadature+index (they are not mounted yet)
This is a 69 tooth gear.
This will be slow going as I will only be able to work on it a few hours a week.
sam
10 years 8 months ago - 10 years 8 months ago #70537 by BigJohnT
Replied by BigJohnT on topic Matsuura Mc 500v2 retrofit.
Nice gear install.
Are you using a 7I80HD-16?
Which Opto22 cards do you use?
JT
Last edit: 10 years 8 months ago by BigJohnT.
10 years 8 months ago #70550 by timewarp
Replied by timewarp on topic Matsuura Mc 500v2 retrofit.
I would like to hear more about the opto 22 setup as well. Do you need the pci ac5 card? They are always pretty expensive on ebay,
Paul
  • skunkworks
  • Topic Author
  • Moderator
  • Moderator
10 years 8 months ago - 10 years 8 months ago #70551 by skunkworks
Replied by skunkworks on topic Matsuura Mc 500v2 retrofit.
No eBay APP ID and/or Cert ID defined in Kunena configurationthese style boards are a direct plugin to the mesa 50 pin connector.
(really handy)
we used a combination of what we had on the K&T
electronicsam.com/images/KandT/conversio...el/electricalbox.jpg
Last edit: 10 years 8 months ago by skunkworks.
10 years 8 months ago #70553 by timewarp
ok, I read this
linuxcnc.org/docs/html/drivers/opto22.html
and thought I needed the ac5 board.
  • skunkworks
  • Topic Author
  • Moderator
  • Moderator
10 years 8 months ago #70779 by skunkworks
The spacing needs tweeking - but a nice signal.
  • skunkworks
  • Topic Author
  • Moderator
  • Moderator
10 years 8 months ago - 10 years 8 months ago #70901 by skunkworks
Better. The bracket for the index sensor is made and ready to be mounted too.. (that was at 6000rpm)
10 years 8 months ago #70906 by Todd Zuercher
Replied by Todd Zuercher on topic Matsuura Mc 500v2 retrofit.
Looks serviceable, well done!
  • skunkworks
  • Topic Author
  • Moderator
  • Moderator
10 years 6 months ago #72733 by skunkworks
hooked the spindle encoder into the 7i48. seems to count and sees the index.
  • skunkworks
  • Topic Author
  • Moderator
  • Moderator
10 years 6 months ago #72841 by skunkworks
Spindle RPM back to linuxcnc
Time to create page: 0.335 seconds
