gmoccapy new override controls ???
02 Feb 2015 05:21 - 02 Feb 2015 05:22 #55568 by newbynobi
Hallo, what do you think ?
It is only the first idea, to avoid sliders on a touch screen.
The new widget allows to set color, mi and max values and also the increment to apply per button press.
No sliding with the finger.
Norbert
Last edit: 02 Feb 2015 05:22 by newbynobi.
04 Feb 2015 14:50 #55668 by emcPT
My personal opinion is always to have a physical button for feed override and spindle - they are simply too handy when you are machining, but your screen is good.
04 Feb 2015 23:44 #55688 by Swapper
Looks nice, but would it be impossible to have both functions a slider with the - and + signs?
Or maybe select able in settings.
One thing i miss is that i cant push the slider to jump to any position like in "windows" sliders you can press them anywhere and they jump to that spot.
05 Feb 2015 00:26 #55692 by newbynobi
I think that this behavior is not good on a machine control, at least if you use a touch screen. One wrong touch could lead to a crash if you accelerate to max accidentally.
Norbert
05 Feb 2015 00:27 #55693 by newbynobi
You are right, but many users do not have that hardware knob.
Norbert
05 Feb 2015 00:39 #55694 by DaBit
Seems much better; the standard sliders are a royal PITA on a touchscreen. My XHC-HB04 MPG has the option to control feed/spindle override, but that's not the holy grail either.
I intend to add a few potmeters for those sliders. Using big knobs with a different feel and a feature on them so you can feel the position and type blindly. But it's job# 367 or so on the to-do list...
19 Feb 2015 02:04 #56089 by mmprestine
I would like to have this asap. Would it be in the 2.7?
19 Feb 2015 05:27 #56101 by newbynobi
i'm not working on this at this time because i am out of time so please be patience.
Norbert
12 Apr 2015 00:33 #57687 by jbunch
Norbert,
Instead of a slider for jog velocity how about eliminating the slider (hate them don't work most times). Just make the incremental jog buttons both
incremental and velocity also adding a button that is exported to an input pin for incremental and velocity selection as well .
Add variables for each button to the gmoccapy_preferences file for the velocity that you want on that button. This will work for 90% of all needs and is simple.
Jim
17 Apr 2015 23:59 #57867 by todmorg
I vote YES on the push buttons as a replacement for the sliders.
The sliders are more of a hazard than a help when using a touchscreen without a mouse, the push buttons would be a very good upgrade.
Todd
Moderators: newbynobiHansU
Time to create page: 1.129 seconds
