Time and date on Gmoccapy
10 Jul 2015 00:52 #60541
by LAIR82
Time and date on Gmoccapy was created by LAIR82
Hello Guys,
How do you change the time to a 12hr format, and change the date to MM/DD/YYYY?
I looked at it thru the GLADE editor, but it just say's Time and Date for that section.
Rick
Rick
11 Jul 2015 05:59 - 11 Jul 2015 06:00 #60552
Replied by cmorley on topic Time and date on Gmoccapy
you would have to change gmoccapy's core code by the look of it...
if using a RIP linuxcnc:
in src/emc/usr_intf/gmoccapy/gmoccapy.py
look for a line like this somewhere around line 1371:
self.widgets.lbl_time.set_label( strftime( "%H:%M:%S" ) + "\n" + strftime( "%d.%m.%Y" ) )
change the big H to a big I and then change the order of "%d.%m.%Y"
then remake linuxcnc
Chris M
Chris M
Last edit: 11 Jul 2015 06:00 by cmorley. Reason: add linenumber
11 Jul 2015 22:01 - 11 Jul 2015 22:06 #60567
by newbynobi
Replied by newbynobi on topic Time and date on Gmoccapy
Or you do the changes directly on the file
do not change owner or mode. That is the way you will not need the source or to remake linuxcnc.
For gmoccapy 1.5.3.1 the corresponding line to make the changes is 1364
Norbert
/usŕ/bin/gmoccapy
Norbert
Last edit: 11 Jul 2015 22:06 by newbynobi.
13 Jul 2015 19:50 #60611
by LAIR82
Replied by LAIR82 on topic Time and date on Gmoccapy
Thanks Guys,
That looks better now, that I got it changed.
Rick
Rick
05 Sep 2015 00:53 #62134
by LAIR82
Hey guys,
I take it that these lines and data no longer apply to change this?
I just tried to do this on a current build, and cannot find anything relating to "self.widgets.lbl_time.set_label( strftime( "%H:%M:%S" ) + "\n" + strftime( "%d.%m.%Y" ) )" in the file.
Rick
/usŕ/bin/gmoccapy
Norbert
Hey guys,
Rick
08 Sep 2015 04:10 #62223
by newbynobi
What gmoccapy version?
08 Sep 2015 19:37 #62256
by LAIR82
It looks like 1.5.5, I can't open my config, but a current ( as of last friday ) sim config shows 1.5.5, I looked at ,
And didn't find the " self.widgets.lbl_time.set_label( strftime( "%H:%M:%S" ) + "\n" + strftime( "%d.%m.%Y" ) )" line any where, I searched the whole file, and couldn't find it all.
Rick
/usŕ/bin/gmoccapy
Norbert
Rick
03 Oct 2015 23:56 #63402
by newbynobi
Hallo Rick, sorry for the late answer.
It must be there
in gmoccapy 1.5.5.2 it is in line 1370,
just searche for
def _periodic
and some lines down you will find the line
Norbert
It must be there
just searche for
def _periodic
Norbert
05 Oct 2015 20:48 #63445
by LAIR82
Yeah, I'm not sure what I had going on, but after I did a fresh pull, and re-compiled, it was there and I changed it.
I had a few things fouled up on the machine, but we're back to making chips now
Rick
Rick
Time to create page: 0.248 seconds
