Is someone using Gmoccapy Plasma ?
27 Mar 2016 19:37 #72224
by Michael80
Replied by Michael80 on topic Is someone using Gmoccapy Plasma ?
Normally if you set
HOME_SEARCH_VEL = 0
it will home the axis immediatly if you press the homing button
Wiki --> No_Switches
imperial units, sorry not my place, maybe you can ask newbynobi about it, he was programming the interface Gmoccapy
BR
Michael
HOME_SEARCH_VEL = 0
BR
Michael
28 Mar 2016 11:25 #72241
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Is someone using Gmoccapy Plasma ?
You could also set the NO_FORCE_HOMING = 1
and the units is set in the INI file. The default is imperial but you can set it to mm
Regards
Marius
www.bluearccnc.com
- islander261
- Thank you received: 216
28 Mar 2016 14:37 #72246
by islander261
Replied by islander261 on topic Is someone using Gmoccapy Plasma ?
Thank you, I have my setup working with manual homing now. This is still a test setup with no hardware connected.
The next strange thing is also probably setup related. I am want to use imperial units (inches). In my .ini file in the [TRAG] section I have the LINEAR_UNITS = inch and in the [DISPLAY] section I have INCREMENTS = .1in .05in. .01in. ... But something still isn't right. When I jog using a step move with the resolution set to .1in the DRO shows a move of 2.540. This behavior is the same just scaled if I use another step size. It is almost as if the DRO is still counting in mm. I will be reading up on gmoccapy more today to try and find the problem but any hints are welcome.
- islander261
28 Mar 2016 14:41 #72247
by islander261
Sorry I forgot to attach the needed files.
28 Mar 2016 17:09 #72253
by mariusl
Regards
Marius
www.bluearccnc.com
When you look at the "Active Gcodes" do you see an G20 or G21?
Regards
Marius
www.bluearccnc.com
Time to create page: 0.083 seconds
