File Open Dialog - No Network Drives
I'm not very familiar with Linux, so is there some configuration change needed to enable this so I'll be able to directly open networked files from within Gmoccapy? Currently I'm having to copy files to a local folder before I can use them.
Don't use Gmoccapy, so not familiar with its dialogs, but if it is just another linux machine, cifs is probably one of the easiest to use, to mount a network drive to a local folder, should also work with a samba share
This seems a reasonable howto
linhost.info/2012/05/mount-a-network-share-in-linux-ubuntu/
- Thank you received: 1369
bash: mount.cifs: command not found
What did I do wrong?
I just tried installing cifs-utils (using synaptic) and the command mount.cifs returns this
No idea. I have just installed cifs-utils on Jessie and it works fine.
I just installed on the command line.
If you can't get man mount.cifs to show you the man page or mount.cifs -v to show you the version, it is not installed.
I'll try another of the GUIs available to see if I have the same problem. I was thinking I had been able to do it on a previous version of LinuxCNC, but could be wrong.
Considering the files are on a Windows box, should I still be using cifs-utils and the mount commands listed above?
I found this set of instructions to be quite helpful as well.
wiki.ubuntu.com/MountWindowsSharesPermanently
Anyway, I would open your share that you are trying to access with file browser from there you should be able to copy the path name for it. (should be something like smb://your_windows_share/)
Next you need to create a directory where ever you'd like to mount your network share. (my example will use /home/username/linuxcnc/ngcfiles/network)
Then after you've installed cifs-utils, you can do a test mount to make sure you've gotten it all straight. From a terminal type:
sudo mount.cifs //your_windows_share/ /home/username/linuxcnc/ngcfiles/network/
This will mount your windows share at that location. Check to see that it is there with a file browser or in Linuxcnc.
Unfortunately this will disappear next time you reboot. To make it perminant you will have to add an entry to the fstab file in /etc/
To do that you must have root privlages, so from a terminal type sudo leafpad /etc/fstab (or use sudo "what ever editor you like"). At the bottom of the fstab file add a new line :
//your_windows_share/ /home/username/linuxcnc/ngcfiles/network/ cifs guest,uid=1000,iocharset=utf8 0 0
reboot your computer and make sure it works. If your windows share requires certain usernames and passwords you will need to make adjustments to the fstab line.
Oh and about spaces in your path names. The terminal command mount.cifs when a directory has a space or other special character in it put that directory name in double quotes such as //server_name/"dir name"/ but in the fstab file you use \040 to replace a space like this //server_name/dir\040name/
I appreciate the help.
The files I'm trying to access are on a Windows 7 system attached to my home network through a router. Using the Linux File Manager, I can get to the files without any sort of mount commands. The files/folders are designated "shared" on the Windows system.
Most file dialogs used in programs come from the SDK from that language and populate their file trees simply from detected files using similar to a ls command.
The more advanced file managers, especially those integrated into the system, do all sorts in the background.
They automatically mount your mobile phone through MTP using the /proc system, create a directory and mount inserted USB sticks onto it, automatically mount detected network shares etc etc
The killer for sharing from windoze to Linux, is very often the awful file names, full of spaces, multiple periods, asterisks, brackets or escaped sequences to try to overcome them if accessing in a browser.
In very many Linux programs a space precedes a new argument, a period precedes the extension as far as the parsers are concerned, so they cause problems
Anyone who has tried to download a video ripped by a windoze user, using wget on the commandline will know what I mean.
The safest word separation to use in a filename is an underscore _ . Even a dash - has dangers in some circumstances, where it is possible the name could be seen as an instruction to subtract one named variable from another.
As Todd pointed out you can automatically mount at boot if necessary, be aware of course that the networked drive MUST be available at EVERY boot, or you may hit other problems.
A slow boot is one possibility, already the newer kernels will wait for 1 1/2 minutes at boot up if they find an instruction in fstab to mount a drive by UUID which they cannot resolve.
(NB. Most common reason for this problem if you have it, is that the swap partition was reformatted when a new partition install was done and all the other partitions which mount that same swap, now have the wrong UUID in their fstab - bugged the hell out of me until I realised what was happening )
