Setting units
03 Apr 2016 02:42 #72605
by eman5oh
Setting units was created by eman5oh
I have just started using gmoccapy and used an axis config , edited the diaplay line to gmoccapy as well as the max_linear_velocity to max_velocity to get up and running. How do set the Max Velocity slider to inch units?
03 Apr 2016 11:24 #72615
by newbynobi
Replied by newbynobi on topic Setting units
Hallo and thanks for using gmoccapy,
if your config is in inch, the slider should be in inch.
But if you have G21 in your startup code, all displays will be in mm.
Go to the MDI Page and give G20 as command, to change every display to inch.
Norbert
Norbert
The following user(s) said Thank You: eman5oh
Time to create page: 0.502 seconds
