Some controls not functional after update
07 Apr 2016 19:49 #72928
by mariusl
Regards
Marius
www.bluearccnc.com
Some controls not functional after update was created by mariusl
I just updated my production system to the latest automatic update and found that there are some issues that are new.
When using a touch screen on Gmoccapy and you go to load a new gcode file, the green "right mark" button to load the selected file does not come alive. You have to move the cursor or selection to another file with the left and right arrows on the screen before the green select button is active. Very frustrating new feature Norbert
Regards
Marius
www.bluearccnc.com
08 Apr 2016 21:09 #72978
by newbynobi
Replied by newbynobi on topic Some controls not functional after update
Hay Marius,
You should know me by now:-)
It is allready fixed:-)
I have pushed the bugfix a week ago,but i have no influence on the pubification of new packages.
If you do replace iconview.py with the file from master, all should be OK
Norbert
Norbert
09 Apr 2016 06:13 #72988
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Some controls not functional after update
Thanks Norbert. You are a champion.
Regards
Marius
www.bluearccnc.com
24 Jun 2016 14:35 #76567
by LAIR82
Replied by LAIR82 on topic Some controls not functional after update
Hello Norbert,
For some reason this isn't working, I tried to move the new iconview.py file to the directory to replace it, and I get it moveed properly, but it is still not working properly, the button is still greyed out. This is on an Ubuntu 10.04 build, that I just updated to 2.7.4. I did this to my Wheezy build that I noticed the same issue with, and it worked fine.
Rick
Rick
25 Jun 2016 21:28 #76660
by newbynobi
Should work also on Ubuntu, where did you copy the file to?
27 Jun 2016 11:20 #76702
by LAIR82
I ended up moving the updated .py file to the /usr/share/pyshared/gladevcp/ directory and it worked, I was trying to move it to the /linuxcnc-dev/lib/python/gladevcp/ directory for some reason,
Oh well, my apologies for the alarm, after a little more perseverance I figured it out.
Rick
Rick
Time to create page: 0.090 seconds
