Charge Pump
10 Apr 2016 13:58 #73049
by thor44
Charge Pump was created by thor44
I upgraded to Linuxcnc 2.7.4 using the Debian Wheezy .ISO and i'm running Gmoccapy and when I set up the charge pump it does not work so I set up a test mill in Axis and copied the config in the .INI over to Gmoccapy and it still does not work, I checked the HAL files and there was nothing to copy over so I think I got everything, so why does it not work in Gmoccapy but works fine in Axis?
Orson
Orson
12 Apr 2016 20:48 #73193
by newbynobi
Replied by newbynobi on topic Charge Pump
Please post both config folders, the gmoccapy and axis, so we can try to help.
I doupt it is caused by gmoccapy.
Norbert
Norbert
13 Apr 2016 00:15 #73206
by thor44
Replied by thor44 on topic Charge Pump
here is the config files for both machine set ups.
Orson
Orson
14 Apr 2016 06:38 #73272
by newbynobi
I took a look and found:
- Base and servo periods are different in both configs
- connection of charge pump in hal are different
Please use for gmoccapy and axis the same Base and Servo periods and the same connections in the hal files.
Then report.
Norbert
Then report.
Norbert
The following user(s) said Thank You: thor44
16 Apr 2016 23:32 #73447
by thor44
Yep, that works maybe next time I will pay more attention to what I'm doing. I missed two lines in the hal file, but now it works.
Thanks for taking the time to help me out.
