Gmoccapy gantrykins
14 Apr 2016 06:43 #73274
by mpvriens
Gmoccapy gantrykins was created by mpvriens
Would like to work with gmoccapy on a gantry machine, with gantrykins, I can control 2 joints for one axe,
At this moment i need display "axis" to home the joints in joint mode, then switch to world mode .
Is this also possible with gmoccapy?
14 Apr 2016 16:38 #73312
by newbynobi
Replied by newbynobi on topic Gmoccapy gantrykins
I have never had a gantry machine, so actually gmoccapy does not support joints mode.
It will not be to complicated to integrate that, but I need someone with a real machine and willing to advice me on the
"how to do" side.
Norbert
"how to do" side.
Norbert
14 Apr 2016 18:59 #73321
by mpvriens
Replied by mpvriens on topic Gmoccapy gantrykins
Hi Norbert
Thanks for your quick replay
We are very enthousiastic about the gmoccapy gui, and till now we have used it on almost all our retrofit machines.
Actually, i'm more familiar with gmoccapy as with Axis at this momnent.
We now have started build als new machines from scratch.
At this momnent we are building a resonable big machine made out of steel bars and plate
Size 4800 x 2050 with a moving bridge of about 300 kgr.with two 1,5 kWatt motors
We would like to use gmoccapy as the gui, only challange we had to switch to the gantrykins, as the solutions we have used till now ( master slave ) was causing stress on the bridge , as there was no feedback from the slave to the master.
With gantrykins, the machine starts in joint mode, and after homing all joints the machine has to be switched to world mode.
I found that with the gantrykins installed, i still can move the motors with gmoccapy, only i don't have dro reading of position,
Also i don't know how to switch from joint mode to world.
I'm using linuxcnc 2.74 , and mesa 5i25 with 7i77 .
15 Apr 2016 21:45 #73372
by newbynobi
Where is your config?
Is it a XYYZ or XYZY config?
First one is problematic!
Try to build a sim config, so i can test with that one.
Norbert
Norbert
16 Apr 2016 06:33 #73391
by mpvriens
my config is XYZY
I think for homing in joint mode sequence would be : Z , X, Y1andY2 (y1 and y2 simultaniously)
Marius
Marius
20 Apr 2016 06:45 #73629
by mpvriens
Have attached my hall and ini file ,
I expect homing won't be an issue , as long as it is possible to switch from joint to world ,
homing in axes is done with home switches on all 4 axe.
20 Apr 2016 06:47 #73630
by mpvriens
sorry, didn't attach the ini
21 Apr 2016 16:50 #73693
by newbynobi
I have tested a little bit, but I am not sure how to change the modes from python side.
So this will need some more time.
I will keep informed.
Norbert
Norbert
The following user(s) said Thank You: mpvriens
21 May 2016 18:55 #74919
by mpvriens
Can you explain what exactly happens when changing from world mode to joint mode, as also the DRO's will not show encoder positions
23 May 2016 16:58 #74996
by newbynobi
In world mode you are moving in a cartesioan coordinate system, in joint mode each joint is moved individually.
I have not looked further on a solution, because there are too many thinks to do in my private live at the moment..
Norbert
Norbert
