Home all button
21 Apr 2016 18:58 - 21 Apr 2016 18:59 #73695
by pommen
Home all button was created by pommen
Hello there,
I've been using Gmoccapy a bit now and I'm loving it.
In the homing menu there's a the X Y Z buttons, and they work well for me. There are however a a "home all" button I cant get to work. Is there something that I need to enable/change to make that button home all axies at the same time with only one button push?
/Peter
/Peter
Last edit: 21 Apr 2016 18:59 by pommen.
- cncnoob1979
- Thank you received: 75
21 Apr 2016 23:20 #73702
by cncnoob1979
Replied by cncnoob1979 on topic Home all button
Hey!
Haven’t had any issues that you are experiencing. Have you made any modifications?
22 Apr 2016 02:27 #73707
by joekline9
Replied by joekline9 on topic Home all button
do you have HOME_SEQUENCE =
in each [AXIS] section of your ini file?
[AXIS_0]
HOME_SEQUENCE = 1
[AXIS_1]
HOME_SEQUENCE = 2
[AXIS_2]
HOME_SEQUENCE = 0
[AXIS_0]
HOME_SEQUENCE = 1
[AXIS_1]
HOME_SEQUENCE = 2
[AXIS_2]
HOME_SEQUENCE = 0
The following user(s) said Thank You: pommen
22 Apr 2016 17:40 #73723
by pommen
Replied by pommen on topic Home all button
That was a really good guess joekline9!
it worked as soon as I entered the HOME_SEQUENCE
The ini file is mainly made from PnCConf. Not sure if I accidently deleted the entries before, of if they were never there ro begin with. Nonetheless, its works great now. Thanks!
/Peter
/Peter
The following user(s) said Thank You: joekline9
- AlbertHall
23 Jun 2017 14:34 #94842
by AlbertHall
Replied by AlbertHall on topic Home all button
Would those settings be overwritten if I use stepconf?
- Online
- Thank you received: 1369
23 Jun 2017 14:44 #94846
Replied by Todd Zuercher on topic Home all button
If you changed or added them, yes.
Time to create page: 0.215 seconds
