Gmoccapy config
06 Jul 2016 20:29 #77105
by newbynobi
Replied by newbynobi on topic Gmoccapy config
That is very strange, what distro do you use?
I use debian jessie and Ubuntu to test and did not had this behavior.
A quick solution would be:
openwith a normal text editor (you will need root rights)
search forthen look forand change the number 200 to 250, save and try.
Norbert
open
/usr/share/gmoccapy/gmoccapy.glade
search for
box_info
<property name="height_request">200</property>
Norbert
The following user(s) said Thank You: vre
07 Jul 2016 01:30 - 07 Jul 2016 23:19 #77121
by vre
Replied by vre on topic Gmoccapy config
Iam using wheezy and with this patch (from 200 to 250) all are fine thank you.
One more question..
I have setup xhc-hb04 mpg pendant and i have a button that executes in MDI G10 L20 P0 X0 Y0 Z0
to zero workpiece.Everything works fine except that live plot does not update to new 0.
I have to reopen the ngc file for updating the live plot .
Is there any solution for automatic updating live plot after MDI G10 L20 P0 X0 Y0 Z0 ?
One more question..
Last edit: 07 Jul 2016 23:19 by vre.
Time to create page: 0.121 seconds
