gmoccapy 2.1.0 has been released
03 Aug 2016 18:43 - 03 Aug 2016 18:47 #78335
by newbynobi
gmoccapy 2.1.0 has been released was created by newbynobi
Hallo,
I released gmoccapy 2.1.0
What is new?
You may take a look on YouTube
Norbert waiting for your comments
What is new?
- gmoccapy does support the new master branch, supporting Joint Axis mode
- It does support 5 axis
- it supports 8 joints
- The program name moved to the preview, leaving more space in the info tab
- New touchscreen controls, replacing the previous used sliders
- Unfortunately renaming of hal pin to group them, so be aware that you will have to change hal files
Last edit: 03 Aug 2016 18:47 by newbynobi.
- Thank you received: 5934
03 Aug 2016 20:25 #78338
Replied by tommylight on topic gmoccapy 2.1.0 has been released
From a glimpse .......much better !!!
I use mostly FHD monitors, so using Gmoccapy was not on the list, but i do like it very much on low resolution screens.
I never had the time to fiddle with it to make things i need bigger, as i use a lot of plasma cutters, and that was for me unusable.
Will give it a try for sure ( i always do ), and report back.
Danke schon, Norbert
MFG
Tom
MFG
Tom
04 Aug 2016 05:47 - 04 Aug 2016 05:49 #78344
by newbynobi
Replied by newbynobi on topic gmoccapy 2.1.0 has been released
Thanks Tom,
gmoccapy runs fine on Full HD, (1920 x 1080), at least here
I unfortunately do not have a TouchScreen with that resolution, my touch has SXGA (1280 x 1024) and I made all controls to be used with the finger on that resolution. Most users seem to use still a mouse What Gui do you use at the moment?
Do you know gmoccapy_plasma? A screen supported from Marius special made for plasma cutter. It is original gmoccapy with Emmbeded Tabs on nearly all posible places!
If you make a draft of the screen you need, I could look if it possible to realize. Just changing the size of the controls is easy and can be done in very short time. It is just editing the glade file and replace the existing one.
So waiting for your screen design sketch
Norbert
Norbert
Last edit: 04 Aug 2016 05:49 by newbynobi.
04 Aug 2016 09:52 #78347
Thank you very much, Norbert,
I do know of a plasma gmoccapy and i was referring to it for having way to small buttons and stuff under the main screen when used with a FHD screen.
I can use anything for my needs, and i use AXIS mostly as it is very elegant and without clutter, and it is easy to get used to from the customers point of view, but gmoccapy looks more industrial so i would like to use it with touch screens.
Thank you for offering to modify it to my needs, i really appreciate it, but i realy like the way it looks and feels with the new sliders, so we are all good.
With utmost respect,
Tom
Tom
04 Aug 2016 23:29 #78371
Well, this is how it looks on 2 of my laptops and 2 monitors attached to plasma and a micro mill.
Regards,
Tom
Regards,
Tom
09 Aug 2016 09:05 #78514
by Rubenv
Replied by Rubenv on topic gmoccapy 2.1.0 has been released
Norbert
Maybe a stupid question, but how do I get it?
Ruben
Ruben
09 Aug 2016 20:14 #78540
by newbynobi
Hallo Ruben,
A question is neve rstupid, only persons not willing to answer
It is included in master, so get it through git or buildbot.
If you need help, we are here!
Norbert
Norbert
28 Aug 2016 17:24 #79604
by Rubenv
Thanks Norbert!
Do you know when it will be released with the normal build cycle?
R
R
28 Aug 2016 20:08 #79611
by newbynobi
No, sorry.
Norbert
Norbert
30 Aug 2016 17:40 - 30 Aug 2016 17:41 #79731
by tarasko
Replied by tarasko on topic gmoccapy 2.1.0 has been released
Hi. First of all thanks for a new release of this cute interface.
I want to report a few bugs.
1. Spindle speed is reporting 0 when I'm running a g-code program with command 's12000 m3'
2. Transition from AUTO -> MDI doesn't work when I'm pressing F3 key after program finish.
Thanks.
Thanks.
Last edit: 30 Aug 2016 17:41 by tarasko.
Time to create page: 0.156 seconds
