Reload Tool on start up, new feature in gmoccapy
01 Jan 2017 14:28 #85012
by newbynobi
Reload Tool on start up, new feature in gmoccapy was created by newbynobi
Hallo dear users
do you know the following annoying situation?
You start your machine, home all axis and want to start a quick job, but before you need to go to the tool tab or to MDI and reload the tool, that is currently mounted in your spindle.
That is not any more necessary!!
Release 2.2.0 offers a switch on the settings page to reload a tool on start up!
It is checked by default, as I do think that this is the way it has to be
It works the following way:
when gmoccapy receives the signal that all axis are homed, the tool will be reloaded with the command:
Please see, that also length compensation will be loaded!
Hope you like that new feature, otherwise just go to the settings page and disable it.
Norbert
M61 Q <saved tool number> G43
Norbert
08 Jan 2017 17:32 - 08 Jan 2017 18:49 #85480
by timmert
Replied by timmert on topic Reload Tool on start up, new feature in gmoccapy
good work
I just started working with LinuxCNC and Gmoccapy and came across the 'problem' that I had to do a G43 each time I startup the machine
Any advise on how to update gmoccapy?
Last edit: 08 Jan 2017 18:49 by timmert.
11 Jan 2017 17:26 #85617
by newbynobi
Replied by newbynobi on topic Reload Tool on start up, new feature in gmoccapy
@timmert
if you use buildbot, just use synaptic ore apt
if you build from source, just pull and recompile.
Norbert
Norbert
12 Jan 2017 16:31 #85657
by timmert
Thanks for the info.
I upgraded with synaptic and got the latest version.
But isn't it possible to use the new Gmoccapy update with version 2..7 stable release? I don't want to use the master.
- Thank you received: 1370
12 Jan 2017 19:17 #85661
Replied by Todd Zuercher on topic Reload Tool on start up, new feature in gmoccapy
No.
12 Jan 2017 19:18 - 12 Jan 2017 19:18 #85662
by timmert
ok, I'm going to cry in a corner
Last edit: 12 Jan 2017 19:18 by timmert.
12 Jan 2017 19:32 #85663
The problem is because of the merger of the Joints/Axis branch into Master, there was a significant restructuring of how the machine and user interface is configured. Making porting from that version to an earlier one impractical. It would be easier to to add/change what ever feature you like in the old version than to try to use the new one.
12 Jan 2017 21:34 #85674
by newbynobi
It would be possible to add that Feature also to 2.7 release, but new stuff should go only to the development release, meaning master and the stable release will only get bug fixes.
I do like that way it is handled in linuxcnc comunity, as otherwise the stable release could easily become unstable due to new features.
Norbert
Norbert
12 Jan 2017 22:05 #85676
by timmert
makes sense
I will upgrade to the master release soon.
Keep up the good work, I really like gmoccapy
23 Jan 2017 18:37 #86500
by newbynobi
Tool stuff solved, and pushed.
Norbert
Norbert
Time to create page: 0.135 seconds
