Change Design Goccapy
- Holzwurm56
- Thank you received: 3
28 Jan 2017 22:30 #86862
by Holzwurm56
Change Design Goccapy was created by Holzwurm56
Hello,
its possible to change the design of Gmoccapy? Is there a manual available?
Hans
Hans
- Thank you received: 2168
29 Jan 2017 10:22 #86892
Replied by cmorley on topic Change Design Goccapy
It is possible - you can change anything you like in linuxcnc.
Depending on how much you wish to change,
you need to know about python, pygtk and GLADE.
There is also Gscreen which caters more to customisations which may or may not be appropriate depending on what kind of changes you want and how independent to linuxcnc updates you hope to be.
There is no detailed manual for this.
There is a very basic overview here:
www.linuxcnc.org/docs/2.7/html/gui/gscreen.html
Gmoccapy uses similar techniques.
Chris M
Chris M
- newbynobi
- Thank you received: 394
29 Jan 2017 13:02 #86901
by newbynobi
Replied by newbynobi on topic Change Design Goccapy
Hans,
if you do mention what changes you need, or like, may be others share your opinion and it will be implemented by default.
See gmoccapy_plasma, it is standard gmoccapy with user changes
Norbert
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.846 seconds
