Spindel problems in Gmoccapy
In Gmoccapy I can not start the spindle, works OK in Axis.
Obviously I have something set wrong but what can that be, spindle starts at 200rpm in Axis.
linuxcnc.org/docs/html/gui/gmoccapy.html#_basic_configuration
slider far left was locked
But, still no visual rpm display. Copied TURBO and his solution
I mean i just got the gmoccapy spindle meter and led working.
In the ini hal section I added
# Single file that is executed after the GUI has started.
POSTGUI_HALFILE = custom_postgui.hal
in custom_postgui.hal
net spindle-fb-rpm-abs-filtered => gmoccapy.spindle_feedback_bar
net spindle-at-speed => gmoccapy.spindle_at_speed_led
So how can I get some rpm feedback having only INDEX pulse on spindle shaft.
Cheers
Bengt
# Spindeldrehzahl messen / mesurement spindle revolution #
loadrt encoder num_chan=1
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
setp encoder.1.position-scale 1 # Anzahl der Impulse je Umdrehung
setp encoder.1.counter-mode 1 # Wenn 1 gesetzt, wird B-Signal ignoriert
# disable 4 times encoder, otherwise each klick will ingreas jogwheel-count by 4 instead of 1
# 4-fach-Auswertung vom Encoder ausschalten, sonst wird jogwheel-count bei jedem Klick um 4 statt um 1 erhoeht
setp encoder.0.x4-mode FALSE
loadrt scale count=1 # Wird gebraucht, um U/Sekunde in U/min umzurechnen
addf scale.0 servo-thread
setp scale.0.gain 60 # Ausgang = 60 x Eingang
net spindle_index parport.1.pin-12-in => encoder.1.phase-A => encoder.1.phase-Z
net spindle-index-enable motion.spindle-index-enable <=> encoder.1.index-enable
net spindle-rps encoder.1.velocity => scale.0.in
net spindle-rpm scale.0.out
# Zum Erkennen ob Geschwindigkeit erreicht wurde
# For at Speed detection
loadrt near
addf near.0 servo-thread
# Stellt fest ob zwei Werte in etwa gleich sind
# Wahr wenn, in1/scale <= in2 <= in1*scale
# oder wenn |in1-in2| <= difference
# prooves if two values are roughly the same
# true if in1/scale <= in2 <= in1*scale
# OR |in1-in2| <= difference
setp near.0.scale 1.2
setp near.0.difference 10
net spindle-cmd => near.0.in1
# net spindle-revs motion.spindle-revs => near.0.in1
net spindle-rpm => near.0.in2
net spindle-at-speed near.0.out => motion.spindle-at-speed
After that spindle-rpm must be connected in postgui.hal to gmoccapy.spindle_feedback_bar
May be you need to pass the signal through an ABS to get positive values.
Hope that helps.
Norbert
will give this a try tomorrow.
mfg
Bengt
What lines should be edited to suit above as I get nowhere with the code as-is.
Cheers
bengt
Here is a simple spindle connection I use for a small machine:
########################################################## # Spindeldrehzahl messen / mesurement spindle revolution # ########################################################## loadrt encoder num_chan=1 addf encoder.update-counters base-thread addf encoder.capture-position servo-thread setp encoder.1.position-scale 1 # Anzahl der Impulse je Umdrehung setp encoder.1.counter-mode 1 # Wenn 1 gesetzt, wird B-Signal ignoriert # disable 4 times encoder, otherwise each klick will ingreas jogwheel-count by 4 instead of 1 # 4-fach-Auswertung vom Encoder ausschalten, sonst wird jogwheel-count bei jedem Klick um 4 statt um 1 erhoeht setp encoder.0.x4-mode FALSE loadrt scale count=1 # Wird gebraucht, um U/Sekunde in U/min umzurechnen addf scale.0 servo-thread setp scale.0.gain 60 # Ausgang = 60 x Eingang net spindle_index parport.1.pin-12-in => encoder.1.phase-A => encoder.1.phase-Z net spindle-index-enable motion.spindle-index-enable <=> encoder.1.index-enable net spindle-rps encoder.1.velocity => scale.0.in net spindle-rpm scale.0.out # Zum Erkennen ob Geschwindigkeit erreicht wurde # For at Speed detection loadrt near addf near.0 servo-thread # Stellt fest ob zwei Werte in etwa gleich sind # Wahr wenn, in1/scale <= in2 <= in1*scale # oder wenn |in1-in2| <= difference # prooves if two values are roughly the same # true if in1/scale <= in2 <= in1*scale # OR |in1-in2| <= difference setp near.0.scale 1.2 setp near.0.difference 10 net spindle-cmd => near.0.in1 # net spindle-revs motion.spindle-revs => near.0.in1 net spindle-rpm => near.0.in2 net spindle-at-speed near.0.out => motion.spindle-at-speed
Hope that helps.
Norbert
addf encoder.update-counters servo-thread
setp encoder.0.position-scale 1 # Anzahl der Impulse je Umdrehung
setp encoder.0.counter-mode 1 # Wenn 1 gesetzt, wird B-Signal ignoriert
net spindle_index parport.0.pin-10-in => encoder.0.phase-A => encoder.0.phase-Z
net spindle-index-enable motion.spindle-index-enable <=> encoder.0.index-enable
net spindle-rps encoder.0.velocity => scale.0.in
loadrt near
In your postgui.hal file you need:
net spindle-rpm gmoccapy.spindle_feedback_bar
net spindle-at-speed gmoccapy.spindle_at_speed_led
Norbert
please use the changed code.
See my last post.
Norbert
- Online
- Thank you received: 1370
net spindle-index => encoder.0.phase-Z => encoder.0.phase-A
(There were also other places where encoder.1 should be changed to encoder.0, but Norbert corrected them while I was typing.)
