Spindel problems in Gmoccapy
01 May 2017 09:20 #92418
by tecno
Replied by tecno on topic Spindel problems in Gmoccapy
Edit spindel hal
# IMHO should be 1.0
setp stepgen.2.position-scale 1
tuned LM circuitry reading with halmeter commanded 200 to closest rpm that is approx 204rpm
So please tell me what to measure and with what instrument.
- Thank you received: 1369
01 May 2017 11:55 #92432
Replied by Todd Zuercher on topic Spindel problems in Gmoccapy
I think the missing link to the puzzle lies somwhere in your postguihal file. What you are missing is the hal pin connection of the spindle speed to the gui's spindle speed input pin.
01 May 2017 12:01 #92435
by tecno
net spindle-rpm gmoccapy.spindle_feedback_bar
net spindle-at-speed gmoccapy.spindle_at_speed_led
Spindle hal
net spindle-rpm abs.0.out
Spindle hal
01 May 2017 12:10 #92436
Replied by andypugh on topic Spindel problems in Gmoccapy
Using Halmeter (or halshow) check if the spindle-rpm signal is non-zero. Check the input and the output of the abs, too.
We know that a good number is coming out of encoder.0.velocity, the question is where it is getting "lost" in the HAL
01 May 2017 12:20 #92438
by tecno
commanded 200 rpm
Spindle-rpm 204 rpm
Abs-in 204 rpm
Abs-out 204 rpm
Spindle-rpm 204 rpm
Abs-in 204 rpm
Abs-out 204 rpm
01 May 2017 13:13 #92444
What number do you see on gmoccapy.spindle_feedback_bar ?
If your HAL file has "net spindle-rpm gmoccapy.spindle_feedback_bar" and you see a number on spindle-rpm and not on gmoccapy.spindle.feedback-bar, then it seems likely that the HAL file isn't being run.
01 May 2017 13:20 - 01 May 2017 13:43 #92445
by tecno
Halmeter shows
0 on bar and False on LED
INI
[DISPLAY]
#DISPLAY = axis
DISPLAY = gmoccapy
POSTGUI_HALFILE = postgui.hal
#POSTGUI_HALFILE = custom_postgui.hal
HALFILE = base.hal
HALFILE = spindle.hal
INI
[DISPLAY]
#DISPLAY = axis
DISPLAY = gmoccapy
HALFILE = base.hal
Last edit: 01 May 2017 13:43 by tecno.
01 May 2017 14:53 #92448
Which HAL file makes the connections to the spindle speed bar?
01 May 2017 14:58 #92449
by tecno
Spindle.hal to postgui.hal
postgui
# link to gmoccapy toolchange, so you get the advantage of tool description on change dialog
net tool-prep-number gmoccapy.toolchange-number <= iocontrol.0.tool-prep-number
net tool-prep-loop iocontrol.0.tool-prepare <= iocontrol.0.tool-prepared
net tooloffset-x gmoccapy.tooloffset-x <= motion.tooloffset.x
net tooloffset-z gmoccapy.tooloffset-z <= motion.tooloffset.z
from spindle.hal
# spindle.hal
# holds all stuff related to the spindle control
# First load all needed rel time components
loadrt encoder num_chan=1
loadrt scale count=1
loadrt near count=1
loadrt abs count=1
# Next add them to a thread so they are updated periodicaly
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
addf scale.0 servo-thread
addf near.0 servo-thread
addf abs.0 servo-thread
# Set initial pin values if needed
# position scale =
# The scaling for position feedback, position command, and velocity command, in steps per length unit.
setp stepgen.2.position-scale 0.9
setp stepgen.2.steplen 5000
setp stepgen.2.stepspace 5000
setp stepgen.2.maxaccel 5000
setp scale.0.gain 60
setp encoder.0.position-scale 1
setp encoder.0.counter-mode 1
# make needed connections to hardware
net spindle-step stepgen.2.step => parport.0.pin-06-out
net spindle-dir stepgen.2.dir => parport.0.pin-07-out
net spindle-signal parport.0.pin-10-in => encoder.0.phase-Z
net spindle-signal encoder.0.phase-A
# internal hal connections
net spindle-index-enable motion.spindle-index-enable <=> encoder.0.index-enable
# encoder velocity is in units per seconds
# we use scale to get it in units per minutes
# in postgui.hal we connect the signal spindle-rpm to the gmoccapy pin
net spindle-rps encoder.0.velocity => scale.0.in
net spindle-rps motion.spindle-speed-in
net spindle-rpm-not_abs abs.0.in <= scale.0.out
net spindle-position encoder.0.position => motion.spindle-revs
net spindle-enable motion.spindle-on => stepgen.2.enable
net spindle-cmd-rpm stepgen.2.velocity-cmd <= motion.spindle-speed-out
#Spindle at speed ?
setp near.0.scale 1.2
setp near.0.difference 10
net spindle-comanded near.0.in1
net spindle-rev_per_min near.0.in2
net spindle-at-speed near.0.out => motion.spindle-at-speed
postgui
from spindle.hal
# spindle.hal
loadrt near count=1
loadrt abs count=1
# position scale =
#Spindle at speed ?
01 May 2017 16:12 #92455
Are you sure of the file names?
Does anything else in postgui.hal seem to work?
If you open a terminal window while LinuxCNC is running and use the commandDoes the speed display start to work?
halcmd net spindle-rpm gmoccapy.spindle_feedback_bar
Time to create page: 0.148 seconds
