Gmoccapy backtool lathe
09 Jul 2017 09:43 #95533
by timmert
Gmoccapy backtool lathe was created by timmert
I'm using Gmoccapy interface for my lathe and I'm busy setting everything up. Once lathe mode is actived the jog buttons for X- and X+ should switch if you press the 'Y" button for backtool lathe.
So X+ is at the top of the jog panel, and - and the bottom. Lathe mode is working fine. But the jog buttons don't switch. They work perfectly fine though. But this is a bit confusing.
09 Jul 2017 18:00 #95548
by newbynobi
Replied by newbynobi on topic Gmoccapy backtool lathe
No, that is not correct!
If you use a backtool lathe, you need to set that in yor INI file!
Norbert
Norbert
10 Jul 2017 08:27 #95582
by timmert
Replied by timmert on topic Gmoccapy backtool lathe
Hi Norbert
How should I set it?
Lathe = 1 is configured to active lathe mode
linuxcnc.org/docs/html/gui/gmoccapy.html#gmoccapy:lathe-section
But how do I set backtool mode?
10 Jul 2017 17:23 - 10 Jul 2017 17:24 #95611
by newbynobi
Hallo timmert,
I should put that information also in the section you mentioned,
Please see Section 4.1
Norbert
Norbert
Last edit: 10 Jul 2017 17:24 by newbynobi. Reason: Wrong link
10 Jul 2017 17:25 #95612
by timmert
Thanks Norbert!
Time to create page: 2.093 seconds
