Hide tool table columns
21 Apr 2018 15:10 #109395
by Wischi
Hide tool table columns was created by Wischi
Hello,
i really like the gui of gmoccappy but I want to change the tool table columns. I don't really need the Pocket, X, Y and C column. I already looked at the tooleditor widget at the gladevcp wiki site, but I can't figure out how to hide the columns. How does it work?
21 Apr 2018 16:59 - 21 Apr 2018 16:59 #109401
Replied by andypugh on topic Hide tool table columns
It is done by adding settings to the INI file:
linuxcnc.org/docs/html/gui/tooledit.html#_column_selection
Last edit: 21 Apr 2018 16:59 by andypugh.
21 Apr 2018 18:18 #109403
by Wischi
Replied by Wischi on topic Hide tool table columns
I tried it but it didn't work in gmoccapy, only in Axis it showed only the selected columns.
22 Apr 2018 02:04 #109415
Replied by cmorley on topic Hide tool table columns
Gmoccapy uses the gladevcp widget tooledit:
linuxcnc.org/docs/devel/html/gui/gladevc...ml#gladevcp:tooledit
I'm not sure if Gmoccapy allows easy user customization - but you could easily modify it's python code to do what you want.
I bet Norbert will chime in to give you more direction.
Chris M
Chris M
22 Apr 2018 12:54 - 22 Apr 2018 13:19 #109425
by Wischi
I found a solution:
Open gmoccapy in /usr/bin with mousepad as root. Find the line:
add this line under it:
Now I only have: Select, tool #, Z, diameter and comment. I think it looks more clean this way.
self.widgets.tooledit1.set_visible( "%s" % axis, True )
self.widgets.tooledit1.set_visible( "pxyca", False )
Last edit: 22 Apr 2018 13:19 by Wischi.
25 Apr 2018 05:17 #109576
by newbynobi
Replied by newbynobi on topic Hide tool table columns
If you set up a new tool, you might get problems, because you hide the p column, so linuxcnc will place all tools in pocket 0.
I added to my todo list the ini reading for the option to hide columns.
Norbert
Norbert
- HalaszAttila
- Thank you received: 5
12 Apr 2022 09:53 #240030
by HalaszAttila
Replied by HalaszAttila on topic Hide tool table columns
Hello,
any changes in this topic? Is this possible to hide colums in gmoccapy?
12 Apr 2022 10:35 #240034
by Wischi
Hello,
I used the solution from my reply #109425 for a long time. Never had any problems.
The following user(s) said Thank You: HalaszAttila
Time to create page: 0.142 seconds
